A6 Window VAG Recode
Was 15885 went with 15977
Symphony Radio changed to RNS-E a while back Everything works except for windows going down, yes the windows will go up if they are down to begin with. I have tried everything, including using the search tool. Any ideas? |
Also the key in the door controls window up perfect but...
The key in the door will also not roll the window down, yes they roll down fine from the cotrols in the door. Never ever acted up on me.
This is very odd. |
This is what I used, hope it is of value
Tech Article Title Author Date
Coding the Control Module for the A6 John Stahmann 2000 The Audi A6 comes with several pre-programmed functions in the central locking control module that can be accessed by using the VAG 1551/1552/5051 tools (available to Audi dealers), or PC emulation programs such as the old VWTool, Baum's VDS-PRO, or Vag-Com from Ross-Tech. These tools can be used to check your car's diagnostic codes, but they also allow you to make certain modifications to the default programming. Listed below are several of the codes that will modify the central locking control module in the Audi A4 to access some of the hidden features available on these cars. Please note that Audi of America does not officially recognize that these codes exist and some dealers are unwilling to make modifications to the factory control module coding. You assume all responsiblity and liability associated with these modifications. To make modifications to the factory settings, numbers are added to and subtracted from the default setting code numbers. Below is a table that lists several of these functions and the programming required to access these functions. The value is the number added to or taken away from the default programming. Please note that these codes are for cars in the North American market. Function Value Add Window Up/Sunroof close, and Window Down with remote.* +64 Add 1 touch unlock of all 4 doors, trunk -04 Remove horn honk when arming -1024 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed) +32 The coding depends on which radio is installed in your car from the factory. The table below shows the total coding value for certain functionality 'packages' that I have experimented with. Functions Coding with Concert Radio Coding with Symphony Radio * (Factory Default) * Safety Central Locking** * Horn sounds when arming * Lights flash when arming 16140 15885 * Window control with remote * 1 touch unlock of all 4 doors * No horn sound when arming * Lights flash when arming 15176 14921 * Window control with remote * 1 touch unlock of all 4 doors * Horn sounds when arming * Lights flash when arming 16200 15945 * Window control with remote * Safety Central Locking** * Horn sounds when arming * Lights flash when arming 16204 15949 * Window control with remote * Safety Central Locking** * No horn when arming * Lights flash when arming 15180 14925 * Window control with remote * 1 touch unlock of all 4 doors * No horn sound when arming * Lights flash when arming * Automatic door lock/unlock 15208 14953 * Window control with remote * 1 touch unlock of all 4 doors * Horn sounds when arming * Lights flash when arming * Automatic door lock/unlock 16232 15977 * Window control with remote * Safety Central Locking** * Horn sounds when arming * Lights flash when arming * Automatic door lock/unlock 16236 15981 * Window control with remote * Safety Central Locking** * No horn when arming * Lights flash when arming * Automatic door lock/unlock 15212 14957 *Windows open and windows/roof close only when remote button is pressed for several seconds. **Safety Central Locking - 1 press of unlock opens drivers door, 2nd press opens rest of doors and trunk. Coding Instructions (emulation software) 1. Plug your your computer with emulation software loaded into the Data Link Connector (OBDII port) in your car. This Data Link Connector is located on the driver's side, below the dash, close to the door. Start software. You should see a list of the different modules available. 2. Select your control module that you want to recode. In this case, it's the Central Locking control module. In a direct entry address system (VAG1551/1552) enter address word 35 (Central Locking). 3. Your screen should show the current coding of your control module listed as Software Coding. 4. You want to 'Recode' the control module. You don't need to Login to do this. Select 'Recode'. 5. Enter the coding that you want from the above list, depending on the features you desire, make sure your numbers are correct, select 'Do It' or press enter. 6. Your new features should be available immediately. Coding Instructions (VAG 1551/1552) 1. Plug your your VAG tool into the Data Link Connector (OBDII port) in your car. 2. 'Rapid data transfer. Insert address word XX' should be displayed. Press buttons '3' and '5' to insert 'Central Locking address word 35. Press 'Q' button to confirm the input. 3. 'Rapid data transfer. Select function XX' should be displayed. Press buttons '0' and '7' to select 'Code Control Module' function 07. Press 'Q' to confirm the input. 4. 'Code Control Module. Enter code number XXXXX (0-32000)' should be displayed. Enter control module coding number from above table using the keypad. Press 'Q' to confirm the input. 5. Display will show control module identification and that the coding has been entered. Press the arrow button. 6. 'Rapid data transfer. Select function XX' should be displayed. Press buttons '0' and '6' to select 'End Output' function 06. Press 'Q' to confirm the input. 7. Disconnect your VAG tool from the Data Link Connector. Please note: Beware when attempting to code a 98 or newer VW/Audi with an aftermarket radio. The adapter harness that is supplied by the aftermarket ties the "K" line to VBatt. Any service tool or computer that is used on the vehicle may be damaged unless it has been properly fused. Since these items are not coded from the factory to be readily accessible, and Audi of America does not officially recognize these modified codes, you assume all the risks involved with re-coding your central locking control module. Audi TSB 98-07, which can be found at tech.vw.com covers some changes to the central locking control module that Audi of America does recognize. Please be aware that dealers may charge you for this service, or they may not be willing to perform this service. Some dealers may be unfamiliar with the fact that you can re-code the central locking control module, or they may re-code the central locking control module to factory settings. It would be a good idea to keep a copy of this document with the car in case any questions arise. When forwarding and making copies of this document, please keep it intact. Last Update 6/00 |
