Audi Chassis Codes?
I have a 2002 Audi A6 Avant Quattro with 3.0 engine. I am getting the following codes.
P0421: Warm Up Catalyst Efficiency Below Threshold (Bank 1) C06EE: Unknown code C0759: Unknown code I am not worried about the P0421. I am worried about the Chassis codes and cannot find anywhere that will explain what they are. I just had a local guy change all the belts and I am afraid something got screwed up. Does anyone have any idea what the chassis codes mean and they cause? |
What tool are you using to get these C-codes?
BTW....
Chassis codes are in your VIN number so if you using vagcom you will see them, if so don't worry. |
Originally Posted by Cincinnatistuff
(Post 24522992)
P0421: Warm Up Catalyst Efficiency Below Threshold (Bank 1) C06EE: Unknown code C0759: Unknown code I am not worried about the P0421. I am worried about the Chassis codes and cannot find anywhere that will explain what they are. I just had a local guy change all the belts and I am afraid something got screwed up. Does anyone have any idea what the chassis codes mean and they cause? I ran with the error for at least 18 months and then was shocked at my fuel efficiency gain when I finally did replace my linkage armatures. Oh well, that money is long gone. Pull your engine cover off and see if your armatures are broken. Very inexpensive 15 min fix. |
A4 Phil are you taking about the manifold change over valve link arms?
Armatures are in electric motors, vacuum actuators move arms or levers. |
Originally Posted by jcman
(Post 24523066)
Originally Posted by A4 Phil
(Post 24523118)
I changed both the motors and the levers. One motor had gone bad and both levers had snapped. The bad motor simply would not maintain pressure.
Originally Posted by SloopJohnB@mac.com
(Post 24523196)
You're extremely lucky the rods hadn't frozen in the manifold….99% of the time that is the cause of the links or the vacuum motors breaking.
(Post 24523057)
My P0421 code cleared up when I replaced my linkage armature. Not sure if that is a rule or a coincidence.
Originally Posted by thall6594
(Post 24523517)
Could you find a picture of what needs to be replaced for this?
https://www.audiworld.com/forums/sho....php?t=2852103 Caveats, I am not familiar with the 3.0 engine, and I did not own my VAG at the time so I was relying on the old replace a part and drive and see if the code clears. In this case, the CEL cleared and when I did return to my mech, the code was no longer present... then I moved on to vacuum issues later. :-) |
