C5 starting issues after gearbox removal
Hi guys wondering if anyone can assist me, I have a c5 a6 2.4 auto in my workshop customer complain of noise while running we inspected and determined the noise is coming from the gearbox my tech than started stripping and found that the flexplate/ flywheel was actually cracked than welded, now cracked again. customer than supplied us with a used flexplate which we fitted on and then assembled but to our surprise the vehicle wouldn't start, we check all electrical connection wiring, etc to no avail we had put on the diagnostics and only found a camshaft sensor fault. a buddy of ours told us that when you remove the gearbox the rubber form the intake pipe gets stuck in the throttle body which was check but not luck we then removed the gearbox again and found the phonic wheel/ crack shaft pick up was slightly different which we remove and fitted the old phonic wheel back on. we have exhausted all our options with this vehicle did anyone experience this before?
You probably skipped this step in the factory service manual...
"Mark installation position of drive plate on crankshaft."
Considering that the drive plate can be installed in only one right position and seven wrong positions, I'm going to guess that you had a 90 percent chance of being wrong.
Infinity_UK
09-03-2013 07:01 AM
poly
16
12-01-2006 09:46 PM
El Desamparado
Audi Original "S" Cars
11-30-2006 01:56 PM
COT51E-ukcab
10-01-2005 05:47 AM
mityVR6
06-09-2004 09:07 AM
