Central Locking issue; Scanned with VCDS
Hey guys, so I've been having issues with my locks for the longest time and posted about it. Was told to pull codes from VCDS and I finally got my hands on one and was able to get some faults. None of them seem to pertain to the issue I'm having though?
The issue basically renders my locks useless explanation in my previous post here: https://www.audiworld.com/forums/a6-...issue-2899184/ Basically: >Press lock button on interior switch >Locks lock, then immideately unlock >Dome light stays on permanently >Switch is rendered useless until i take the keys out, lock with the fob then unlock >Only happens when keys are in Heres some VCDS codes I pulled 01366 - Crash Signal (possibly affects the locks??) - Possibly from previous fender bender 01368 - Alarm (Luggage) - Open trunk when armed 01574 - Alarm (Rear Right door contact switch triggered) 01370 - Alarm - Interior motion sensor triggered 01374 - Alarm (Terminal 15/Ignition) - Triggered turning car on while armed 00955 & 00956 - FOB Issue - Battery was dead 00668 - Vehicle voltage terminal 30 - Battery was pulled couple months ago None of these seem to affect the specific issue I'm having. I changed the driver door actuator a month ago to no avail, Im going ****ing nuts. Anybody else have this issue? |
Clear all codes, recreate issue, read codes again.
Since you replaced the actuator, I would dig into the wiring harness in the rubber accordion cover between the door and the body.
What johnkk said! Also make sure you have good batteries in the fobs.
