Check Engine Light Problem
Will reset by itself after a few days.
Dealer got advice from AOA and swapped plugs and wires, cleaned injectors, but didn't cure it. In fact, the light came on as I was entering the freeway 2 blocks from the dealer!
Any new suggestions or insights would be appreciated. None of the ancient postings on this problem seem to apply - loose fuel cap, low fuel level, poor quality fuel, etc.
- Spark Plugs & Injectors
- Oxygen & Air flow sensor
- Engine hoses checked
In the end, the culprit happen to be a small slit in the S hose on the EVAP System (rear of vehicle). This causes the system to loose pressure, which will activate the check engine light sporadically.
The following is the part number for this gadget:
Part # 8D0-201-945-C
Hope this helps
00' S4
Bilstien/Neuspeed Race Suspension
ATP Rivas/Dunlop SP Sports
