Lambda resistance too high?
Ive never had these codes before, what could be the cause?
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-10 - Internal Resistance too High - Intermittent
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 35-10 - Internal Resistance too High - Intermittent
Part No: 4B0 920 980 MX
Component: C5-KOMBIINSTR. VDO D11
Coding: 03283
Shop #: WSC 00000
VCID: 8713E60CA536AE9
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
Coding: 03283
Shop #: WSC 00000
1 Fault Found:
O2 sensors are starting to go. Clear the codes and see how long it takes for them to come back. They might stay off for months. When they reappear in a day or two, it's time for new sensors.
they are all new (within the last 3 mos) with the exception of the drivers side pre cat.
Check the connectors on the firewall, make sure they're clean and secure. I don't remember what engine you have...on my 04 2.7T, the O2 sensor connectors are on the passenger side firewall, there's a green, blue, large black, and small black connector. Caveat...I do not know if they are all O2 sensor connections...but at least two of them are, as I recently discovered :P.
If you separate the connectors one at a time, VAGCOM will tell you which sensor it is...each one throws a different P-code when unplugged.
You'll be able to check sensor resistance once you identify which connectors are Bank 2.
I will check them out and possibly spray some electric parts cleaner in there. Thanks
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
jeffkruse
10-02-2015 09:19 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
