Eng oil & coolant temp 25-50 degrees too high!
Hello, I'm a new member and old Audi owner! I have a 2000 A6 4.2L quattro. Just last week the engine oil and coolant temp gauges started to read anywhere from 25-50 degrees hotter than normal. This in turn has caused my ac to blow hot air. I should also mention that at 45mph up to highway speeds both run exactly where they are supposed to and the ac blows cold. I was told the condenser sits behind the radiator and causes the ac to blow hot when the other temps are high, so I am trying to find out if anyone has any ideas of what could be causing the sudden change in engine oil and coolant temp. Again, it doesn't overheat, at least not yet :), just wondering if this is another common issue and if I should be looking for a sensor, thermostat, fan, or fuse issue? Thanks for any insight you can offer!!!
just a guess but i would say if BOTH your coolant and oil are runing warm they really are and it is a mechanical/ electrical issue and not a sensor . I would just make sure your fans are working right off the bat ..
Joe, welcome aboard! First thing I'd do is verify all cooling fans are working.
Got enough coolant? If so, something is blocking its flow. Maybe the thermostat (not uncommon). Or maybe something else (though unlikely there'd be blockage in plumbing).
Originally Posted by GTA_Driver
(Post 24454492)
Originally Posted by Airbag
(Post 24454499)
i thought of that too but he says at highway speeds it is normal means he might be getting enough cooling from airflow without fans .. and besides .. in for a stat .. petty well in for everything no ? :)
Not sure I got your comment about "in for a stat" ... :| |
(Post 24454502)
When my fans weren't working on the 4.2 A6, the only time the temperature would climb up was in stop and go traffic. As long as the car was moving, it was fine.
Not sure I got your comment about "in for a stat" ... :| so figured checking the fans may be a good start :) |
check oil... does it look clumpy/milky?
Originally Posted by 2.7Lturbo
(Post 24454509)
It's not that much different from any electrical diagnostic on any other modern car, in fact, probably better :)
First, switch the buttons ? You will do well do acquire VAG-COM / VCDS from Ross-Tech if you at all want to get anywhere in diagnosing anything with this car. Without it, you're at the mercy of (in)competent mechanics. And where did you take it for an oil change? Find a good independent mechanic that works on Audis. |
