Is this fair price, front pads and rotors for $560 and rear pads and rotors for $460?
Old 03-09-2007, 09:07 AM
nemesisa6's Avatar
Default Is this fair price, front pads and rotors for $560 and rear pads and rotors for $460?
should I buy my own pads, whats the best... thanks.
Old 03-09-2007, 09:10 AM
*C5 AVANT STYLE*'s Avatar
I buy my own.
Old 03-09-2007, 09:12 AM
VONBOTTLE's Avatar
Default that sounds like a dealer price, my indy installed slotted rotors, axxis deluxe pads,
s.s. brake lines and pentosin fluid for that price
Old 03-09-2007, 09:16 AM
nemesisa6's Avatar
it is the dealer price, feels like a rape.
Old 03-09-2007, 09:21 AM
Cargasm2.7's Avatar
Buy your own...check out rockauto.com
VONBOTTLE's Avatar
Default i was quoted roughly the same from my dealer, so i decided to buy the
upgrade kit from stoptech for $700 and have my indy install it....now i have an upgraded brake package for the same price
Old 03-09-2007, 09:52 AM
BernieBenz's Avatar
Default Never understood why you fat wallets love to replace rotors! They tend to wear true....
used being better than new, and the passive wear sensors become fully effective at the first pad replacement. I always cut off the active sensor leads, they being as useless as C5 headlight washers.
Old 03-09-2007, 10:14 AM
Ritz's Avatar
Default No.
Have you ever actually checked a used rotor with a micrometer? They almost never "wear true." There are almost always grooves and high spots. At a bare minimum you need to put them on a lathe and true them up. As a matter of fact, I don't think I've EVER seen a used rotor spin completely true on a good brake lathe.
The average DIYer doesn't have a rotor/drum lathe in their garage so unless you want to pay someone $15-30 per rotor to cut them (perhaps finding that it's hopelessly out of spec anyway), it is easier to buy brand new ones.
Old 03-09-2007, 10:31 AM
Tech Guru
4Driver4's Avatar
Looks like the honeymoon's over - lol
Old 03-09-2007, 11:29 AM
Jim Will's Avatar
Default If you can change a tire, you can do your own brake job
check out ECS tuning (or any other decent) parts outfit and purchase your rotors and pads for all 4 corners for the price of what the stealership is going to charge you for the rears.
Brakes on a 2.7T is simple, just as simple on any other A6 to be honest.
Would take a first timer about 2 hrs to do all 4 wheels. A veteran can bang out all 4 in about an hour. (and I do my own at home with a floor jack and a pair of jackstands)
Quick Reply: Is this fair price, front pads and rotors for $560 and rear pads and rotors for $460?
