Fog help...
So, recently i've been having fog buildup inside the car. Any usefull tips would be great..
rain-x makes some stuff that works really well...
or you could always move to a warmer climate...
use stoner's invisible glass or sprayaway to clean your windows
instead of clothes or Microfiber, use scrunched up newspaper.... keep your windows clean... that's the best way to keep from fogging.
cleaning windshield very well often will minimize the problem.
And if the windows steam up when you turn on the climate control or it's a warm day
then you may have a heater core or heater core hose hose that is leaking.
Re: Fog help...
Is it "fog" inside the car, or are the windows "fogging up"? Window fog is from moisture hitting a colder (outside) surface (usually). turn on the a/c.the A/c should remove moisture from the interior. Plus, use the stuff that is recommonded above. Moisture droplets condense faster on dust/dirt than on a clean surface, so cleaning should help, but the climate control, if it is working properly should quickly eliminate the "fog"
Make sure you're not running the car in "Econ".
Stop makin out with your gf in the car, spring for a room....
Re: use stoner's invisible glass or sprayaway to clean your windows
Thanks all, much appreciated.
