Headlight gap C5
Headlight gap C5
What is the reason for the gap what can I do to fix that?
My C5 is year 2000
https://cimg6.ibsrv.net/gimg/www.aud...d17344e539.jpg
My C5 is year 2000
The headlight assembly is not properly installed. Remove the headlight and reinstall it.
In addition to the fasteners mentioned in the attached procedure, there is a bracket that must be considered when installing, towards the lower inner corner of the headlight.
Cant it be FL headlight on Pre FL model or something because I don't understand how it is possible to install headlight incorrectly.
Because I measured the old and these headlights, my older ones were about 2.5cm longer.
The pre and post FL headlights are the same.
I tried putting my mothers a6 c5 v6 headlights on my a6 c5 v8 and they didn't fit,
I also bought new aftermarket headlights for a6 c5 cars and they didn't fit,
Well I got both on the car but it looks terrible
Well...looking at ECS they list 4 different P/Ns for headlight sets for 2.7 - for 4.2 they list right and left separately so its hard to tellif these are also different. These ones listed for 2.7 are VIN # dependent, not model year.
I too went on line after reading your post and looked at a couple of different sites. They are indicating different part numbers for A6 non Quattro, Quattro, RS 6, and separate numbers for V 8 cars. Also some vendors listed units as VIN # specific. Recommend you write down the part number molded into your original existing unit, then cross reference with vendors on line. If you search with Google you will get a lot of vendors, be specific when you type in the search request (i.e. 2000 Audi A6, 2.7L headlight assembly)
QuattroHawk
08-10-2008 07:16 AM
Ben's e//S2
11-27-2003 09:23 AM
