heavy resistance while driving...any ideas
Hey,
Its been a while since my last post but I wanted to know if anyone has had problems with their car resisting coasting when taking their foot off the gas...it has heavy drag. Just had tranny rebuilt, tune-up etc but still only get 12-14 mpg city (and I am not that hard on it). It feels like I am always towing a trailer...could it be the brakes? Any other ideas? |
check your tire pressure, and make sure that none of your brakes are frozen in place...
I recall someone finding out that their rear caliper was engaged, and frozen in place so the rear pads on that side only wore out.
Just had new tires & brake pads put on yesterday. Its been going on for a while.
Any other direction?
Any chance you're running aftermarket wheels or change your lugs recently?
Lugs could be the wrong type (i.e. conical vs. round, or vise-versa) or too long, and bottoming out causing resistance. Maybe tech mismatched a set... Has happened before. Might be worth checking, in the off-chance...
Good luck |
Jesse - you know that our cars do not 'freewheel' like most other cars, right? That is a
result of the quattro system design....
That said, have you tried jacking up each of your wheels and rotating each one by hand, checking for excessive drag? |
This is an automatic? Are all five gears working? Is the trans not going above 3 or 4?
Re: Jesse - you know that our cars do not 'freewheel' like most other cars, right? That is a
Thats kind of what I was thinking. I will try jacking up the wheels and repost. The tranny works fine (now) after the 4th rebuild this year!!!
Wheels & Lugs are OEM Thanks for the help. |
Any smell from the brakes after a longer drive? Parking brake sticking a little?
Forgot to add to put it in Neutral while coasting to see if it helps to rule out the trans.
...great idea!
