Help my A6 wont start
Hello, my 2003 A6 3.0 auto. wont start, about a month ago it died as I was coming to a stop at a intersection,pushed it off of the main road and checked fuses ok, I sat there cranking it over and over and it would almost start a little and then die,so I sprayed a little starting fluid in intake and it started right up and then die, so I figured its the fuel pump,towed it to a local garage and they figured the same and changed the pump. When I got the car back it was hard to start, it was cranking fine but was taking 2 to 3 turns of the key to start, then it would run fine,so it was like this for like 3 weeks every time I went to start it, fast forward 3 weeks,go out to go to work already running late, all it does is crank, wont turn over, so I really wear the battery down which I think is already going since the winter,call the garage and tell them the new pumps dead, they finally come tow it,they think its just the battery and put new one in starts up runs fine,still hard to start 2 to 3 turns key cranking it over before it will start,but running fine,put new air filter,fuel filter,and ran some injector cleaner through and running great but still hard to start. Go out to go to work on Fri. dead again,cranking and cranking no start.I dont think its getting any spark,could it be cam position sensors or a crank position sensor, or coolant temp sensor. Any ideas appreciated sorry about long story.thanks
No, none of the garages by me have scanner for my car and the dealer is like 35 or more miles away and I hate going to them anyways. I was wondering if this v-checker on the ecs website worked because I was going to order it, http://www.ecstuning.com/Audi-C5_A6-...ls/Scan_Tools/ ,are there any other hand held scanners or cheaper laptop options that I could go for.
Might be worth seeing if anyone is in your area and willing to scan the car with a VagCom.
http://vagcomlocator.com/tinc?key=Ld...ormname=VAGCOM
hello again, well I bought a vagcom package from ross tech and scanned the car this is what I got any ideas?
VCDS Version: Release 805.4
Data version: 20090602
Wednesday,03,June,2009,17:22:13:11287
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAULT64B83N056775
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016752
Shop #: WSC 02325 785 00200
8 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 002 - Lower Limit Exceeded - Intermittent
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 002 - Lower Limit Exceeded - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 004 - No Signal/Communication - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 002 - Lower Limit Exceeded - Intermittent
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 004 - No Signal/Communication
17769 - Cylinder 3 Ignition Circuit: Open Circuit
P1361 - 004 - No Signal/Communication
17766 - Cylinder 2 Ignition Circuit: Open Circuit
P1358 - 004 - No Signal/Communication
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 FF
Component: AG5 01V 3.0l5V USA 0910
Coding: 0001002
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 R
Component: ABS/ESP allrad 2330
Coding: 06497
Shop #: WSC 02325
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00110
Shop #: WSC 02325
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 15: Airbags Labels: None
Part No: 4B0 959 655 Q
Component: Airbag 8.4EP 2001
Coding: 0000607
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01005
Shop #: WSC 02325
1 Fault Found:
01301 - Control Module for Voice Recognition (J507)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 N
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 02262
Shop #: WSC 08166
WAULT64B83N056775 AUZ7Z0B2261237
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D37
Coding: 15885
Shop #: WSC 02325
3 Faults Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
06-10 - Signal too High - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 L
Component: symphony II NP2 0051
Coding: 00225
Shop #: WSC 01404
Address 75: Telematics Labels: None
Part No SW: 8E0 035 616 A HW: 8E0 035 616 A
Component: Telematik USA1
Coding: 0002303
Shop #: WSC 08166 444 00177
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
End ---------------------------------------------------------------------
76 77
Coding: 0016752
8 Faults Found:
Coding: 0001002
Coding: 06497
Shop #: WSC 02325
Coding: 00110
Shop #: WSC 02325
1 Fault Found:
Coding: 0000607
Coding: 01005
Shop #: WSC 02325
1 Fault Found:
Coding: 02262
Shop #: WSC 08166
Coding: 15885
Shop #: WSC 02325
3 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
Coding: 00050
Shop #: WSC 02325
Coding: 00225
Shop #: WSC 01404
Coding: 0002303
1 Fault Found:
I had the battery off a couple times in the last few days so that could be some of the codes right? and I know there is some vac leaks, so that could be some of them ,and I had the whole pass side string of plugs for the coil packs off too, maybe that is cylinder 1,2,3 codes,what about the engine speed sensor?
My bro has some kind of cord that you hook up under the steering wheel that he bought on ebay and then hacked this program i dont know what it is called but it is awsome. When we hooked it up right away it told me that cilender 2 was misfiring so that was the answer my idol problem.
Dude if you used it could proble help your problem.
The programs awsome we found out my 0 to 60 time and other stuff
