A6 Gearbox
Old 11-08-2010, 10:41 PM
msd29's Avatar
Default A6 Gearbox
Hello,
A6, 3.0, CVT, 2003. Transmission is busted. Need to change my gearbox.
I want to know what type of gearbox do I have in my car. How do I find out my gearbox/transmission code to order a replacement?
A sticker in the trunk said the following:
ENG. CODE/TRANS. CODE : BBJ
Is this correct? Attaching the snapshot of the sticker as well.
Please advice urgently.
Old 11-09-2010, 12:01 AM
Edd W's Avatar
It looks to me like BBJ is the engine code and FSA is the gearbox code.
Old 11-09-2010, 12:37 PM
Redneck Truck's Avatar
I remember a friend of mine, a tech for a local Audi stealer, saying that those gearboxes were easily rebuilt from the bottom, in the car. Have you looked into this? When you say it's busted, what failed?
Old 11-10-2010, 04:42 AM
msd29's Avatar
For starters, the PRND has been flashing for a while now. Reverse gear never got engaged. Next up, the car stopped going past the 1st gear.
Got the car checked by a tranmission specialist, he did some tests and told that a few sensors are out. Need to open the gearbox and replace them. It would cost as much as a good second-hand tranny.
Here is the list of sensors he said were dead and needed replacement:
Air flow sensor
Speed output sensor
Speed sensor
T-gear ring sensor
He also said that replacing these sensors still does not guarentee that the problem is fixed.
So now I am trying to understand which tranny would go with my car? The second hand dealer is asking for the tranny code, which I am not sure about.
Thoughts?
Old 11-10-2010, 08:38 AM
bigdadi's Avatar
http://townhall-talk.edmunds.com/direct/view/.f19d835
A6 CVT Transmission discussion
Old 11-10-2010, 11:54 AM
2.7Lturbo's Avatar
air flow sensor has NOTHING to do with the tranny
Old 11-11-2010, 01:40 AM
msd29's Avatar
Yes, not air flow sensor but the rest are in ways associated to the tranny, right?
Old 11-11-2010, 03:10 AM
bigdadi's Avatar
FSA is Tranny Code.
Old 11-12-2010, 05:05 AM
massboykie's Avatar
Originally Posted by msd29
...Attaching the snapshot of the sticker as well...
Had some time on my hands got these for you from http:// PRSearch.PlanetVAG.com
PRCode: 0GU = emissions concept EU 2 (as of MY 01)
PRCode: 0JL = weight category front axle weight range 11
PRCode: 0YG = weight category rear axle weight range 7
PRCode: 1KD = disc brakes, rear
PRCode: 1LG = disc brakes, front
PRCode: 1N1 = power steering
PRCode: 1SA = without additional engine guard
PRCode: 2ZS = leather trimmed multi-function steering wheel with Tiptronic
PRCode: 3FR = electric sliding/pop-up solar sunroof with automatic pre-selection
PRCode: 3HA = without leather parts scope
PRCode: 3L4 = electric seat adjustment for both front seats, driver's seat with memory system
PRCode: 3NZ = rear seat bench unsplit, backrest split folding
PRCode: 3Y5 = electrically operated roll-up sun screenfor rear window and mechanically operated for side windows
PRCode: 4K4 = radio remote controlled central locking operated from inside and separate trunk release
PRCode: 4KC = side and rear windows tinted
PRCode: 4QP = 3-point airbag seat belts front
PRCode: 4UE = airbag f. driver a. front seat passenger
PRCode: 4X2 = side airbag, front and rear
PRCode: 5D2 = carrier frequency 315 MHz
PRCode: 5MQ = decorative leatherette inserts
PRCode: 6R0 = selector lever cover
PRCode: 6XQ = outer rear view mirrors: powered, separately heated, electrically foldablewith memory function
PRCode: 7K0 = without tire pressure warning light
PRCode: 7Q0 = without navigation device
PRCode: 7X1 = ultrasonic park distance control
PRCode: 8ED = bi-functional headlight with gas discharge lamp, for driving on the right
PRCode: 8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving)
PRCode: 8Z6 = engine cooling system, type 2
PRCode: 9Q2 = multi-function indicator/on-board computer with check control
PRCode: C1X = alloy wheels 7 1/2J x 17 five-arm spider style, offset 45
PRCode: D7A = 6-cylinder gasoline engine 3.0 L/160 kW 30V V6 base engine is T15
PRCode: E0A = no special edition
PRCode: F0A = no special purpose vehicle, standard equipment
PRCode: G1A = six-speed automatic transmission
PRCode: J0L = battery 340 A (70 Ah)
PRCode: T15 = components for base engine, unit 06C.B (aluminum)
PRCode: U1C = instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.)
PRCode: VJ1 = reinforced bumpers
PRCode: X6A = national sales program AGCC countries
Cheers
Massboykie
Old 11-13-2010, 03:27 AM
ChampionMotorHouse's Avatar
THIS IS A LIST OF USED TRANNYS.
http://car-part.com/cgi-bin/search.cgi
Hello,
Please advice urgently.[/QUOTE]
Quick Reply: A6 Gearbox
