Tail gate problem on 1999 A6 Avant
I can not open the tail gate on my 1999 A6 Quatro Avant. there seems to be a short that re-locks every time I try to open the tail gate. I've even disconnected the battery and it still locks.
flex wire to lift gate ?
you should be able to disconnect battery and open with a key no ? just unlock a few times with the key once the battery is disconnected
then look at the wiring harness.
Thanks, but I did try disconnecting the battery but to no avail. The key turns but it doesn't unlock. I'll try that again before I try to remove the lower interior tail gate trim from inside the trunk so, hopefully, I can get to the locks assemblys.
It also has the function of locking the rear door so the electric lock won't unlock not if I turn the key 90degrees clockwise and then return it to center and remove the key.
Ed Page
04-28-2022 05:46 AM
jon_bondy
A4 (B7 Platform) Discussion
11-30-2017 11:52 AM
mkongsiri
03-06-2017 10:26 AM
