How remove drivers side door panel
c4 forum is pretty dead, so perhaps your door card removal process is similar to c5. If so, first open door and remove two phillips screws at top front and rear of door panel. Then remove window switch panel from handle and disconnect switch. On c5's you unclip switch panel with small screwdriver through hole in bottom of handle to access clip. Push clip back with screwdriver to release switch panel and then unplug switch panel. Yours might be different, ie just pry up on window switch panel.
Then lift straight up on door card and unhook cable that goes to lock.
Just for the heck of it I copied and pasted your question into google. How do I remove drivers side door panel in a 1995, 1996, 1997 or 1998 Audi A-6
Don't know if these are your car, watch and see.
micho69
08-27-2012 05:02 PM
A6turbo530
09-24-2006 08:30 AM
