Difficulty Getting into 1st Gear
We have the engine & trans pulled from the car to change clutch, engine mounts, turbos, etc.
C5 A6 2.7T 6spd MT
The clutch was slipping & my son mentioned that he had been having difficulty putting car into 1st gear. All other gears engaged easily, but not 1st.
We're changing the clutch assy, along with flywheel & bearings. Also going to do front & rear trans seals & drive axle seals. Didn't want to get into transmission, & I'm hoping worn clutch is our 1st gear problem.
The clutch plate was worn almost down to the rivets. Can a worn clutch be the cause for trouble getting into 1st gear?
C5 A6 2.7T 6spd MT
yes. but it should also have affected other gears...
Don fvcking Juan
05-02-2007 09:00 AM
T-28-Quattro de VT
08-27-2001 03:54 PM
