Interesting dealership comment about Check Engine light
Old 11-26-2001, 01:19 PM
Senior Member
phred's Avatar
Default Interesting dealership comment about Check Engine light
Mine has come back on, so it needs tending to. The first time they just cleared the codes, and now it's back. I suspect minor vacuum leaks.
Anyhow ....... when I called to make the appt (which is only 3 weeks away), I said the light was on so did that matter? Only if it's flashing, sez the dealership, in which case do not drive. Who knew what a wondrous device this was?
Old 11-26-2001, 04:55 PM
QCRAZY's Avatar
I heard that from my dealer too!!
Old 11-26-2001, 05:46 PM
DWP
DWP's Avatar
Me too!
Old 11-26-2001, 07:02 PM
Member
Definitely's Avatar
Default Similar comment on my ex-Volvo
The light came on while driving down the highway. Turned out the gas cap wasn't screwed on properly. They said that the gas cap issue is the major cause of OBD-II lights coming on.
Old 11-26-2001, 07:41 PM
Richard Solomon's Avatar
Default Gotta have Vag-Com...
...to know which MILs are important and which aren't. AESIS and your manual both state that flashing MIL indicates conditions which can damage the catalysts - thus EPA requires immediate repair. You can still melt your pistons with a non-flashing lean code but it won't harm the environment, so no one cares (but you).
My '00 threw both banks lean DTCs with a solid MIL. Since I knew the codes were *BAD* I marched in and got a same-day replacement of my MAF sensor. Would a 3+ week wait while running lean have melted anything? Dunno, don't care.
Know the codes!
ELIZA86
Q5/SQ5 MKI (8R) Discussion
02-18-2018 12:17 PM
gmartinez
Audi A3 / S3 / RS 3
12-20-2012 04:38 PM
buned
11-03-2008 06:16 AM
kitskarTT
11
11-04-2002 10:39 AM
Boston3.0_CVT
10-01-2002 11:38 AM
Quick Reply: Interesting dealership comment about Check Engine light
