Multiple CEL codes on 2003 A6 3.0
Hello,
I am needing assistance on my 2003 3.0 A6, 160,000 miles, with multiple CEL codes I keep getting.
P0346-Camshaft position sensor A
P0300-Random multiple cylinder misfire
P0301-Cylinder 1 misfire
P0302-Cylinder 2 misfire
P0303-Cylinder 3 misfire
P0304-Cylinder 4 misfire
P0305-Cylinder 5 misfire
P0306-Cylinder 6 misfire
P0171-System lean bank 1
P0174-System lean bank 2
P0102-VAF/MAF low input
P0492-Secondary air system bank 2
P0491-Secondary air system bank 1
The car idles rough and dies occasionally at idle, then becomes difficult to start.
I know this is a lot of codes at once, but what can I do to fix this. What needs replaced, and where are these defective pieces located?
Thank you for your help
What did you do the last time you did something to the car/engine or had something done to it? Think back...it's unusual to have so many codes unless a connector got damaged or a ground lost or a sensor went out. Sensor going out might not be the result øf a maintenance-induced failure, but the others often are.
Hello,
Hello,
Cheekmatthew9995
15
01-26-2015 03:51 AM
Onebad S4
03-12-2008 03:32 PM
Kingttr
05-30-2007 02:56 PM
