OBD
Hi trying to access my OBD codes via my climate control. I have a 2003 a6
Heater core problems but want to check to see if my temps are set correct.What buttons do I use to activate and toggle thru the menu. Thanks. |
Originally Posted by Ladder1
(Post 24608843)
Heater core problems but want to check to see if my temps are set correct.What buttons do I use to activate and toggle thru the menu. Thanks. Out of curiosity, where did you hear you can access codes via the climate control? |
There are / were some limited functions available via climate control. I never made them work.
If you never got it to work, how do you "Know"?
There's a video on YouTube. Just Google on board diagnostics for Audi but mines not functioning the same way that video is I can't seem to toggle thru The menu. trying to eliminate any possibilities of something else been wrong before I replace my heater core.I really really really don't want to do it.you want have any suggestions I could use some help here.
(Post 24608990)
Before you do anything check for any codes with vagcom, if no codes exist then check the temp difference between the inlet/outlet of the heater core to determine if it's clogged causing a resistance of flow, there has been many posts about restricted heater cores with a good amount of detail on diagnostics and remedies. |
BTW, if you are referring to this link right out of the tech section for A4's and S4's AudiWorld Tech Articles I don't believe that this applies to the C5 newer than 02.
You can try, Good Luck! |
Yes that's what I am trying to accomplish here I am trying to eliminate things so I can determine whether or not my heater core is bad
(Post 24609039)
why dont you back up and tell us exactly what you are experiencing .. there may be threads or people here that can help .
