outputshaft(driveshaft) bolt removal
Hey, guys, how do I get access to the top two bolts of driveshaft? One other post that I read states that by leaving Emergency Brake off will allow me to spin driveshaft freely. I already tried it but didnt worked.
I have car front raised on jackstands, but my rear wheels are on ramps, could this be the reason why driveshaft its not moving? All wheels must be raised using jackstands?
Yes, in order to remove the driveshaft you will need to remove the bracket from the chassis. When you reinstall it, it will need to be perfectly aligned in order to minimize vibration. Audi has a special tool for aligning, but I used a laser pointer to align it with no apparent problems...
Okay so now, Im on my final step of removing the driveshaft flange, so I can replace my leaking seal, my flange has a 40 torx bolt in the middle, whenever I try to break it loose flange keeps turning with it as well, is that supposed to happen and eventually come off,or it needs to be held with something, need some advise please. This project is getting somewhat frustrating.
(To be honest, you can also use a screwdriver long enough to jam it agains the case of the transmission. I have found the metal in the output flanges to be especially resistant to damaging the bolt hole threads.)
Not a good idea to mix different greases. If the driveshaft looks like it has enough (it usually does), leave it alone and don't add any grease. The driveshaft is not under the types of stresses that halfshafts endure.
If you are just changing the tailshaft seal, this is not necessary at all. Do not do this. Those bracket bolts are adjustable, and there is a special tool needed to align the shaft for proper re installation. You may get lucky, but you may introduce a vibration. Leave the bolts in place.
When I removed the flange I didn't payed attention the way I took it appart from differential, it was turning as I was loosening the bolt that was on the middle of it. I made previous marks with white out to differential and flange and driveshaft, so I just reinstalled the flange to my judgement and matched its marks that I made with those of the differential. Is it a big deal the way how you install it? Or it only matters how driveshaft aligns to differential.
