outputshaft(driveshaft) bolt removal
#12
When I removed the flange I didn't payed attention the way I took it appart from differential, it was turning as I was loosening the bolt that was on the middle of it. I made previous marks with white out to differential and flange and driveshaft, so I just reinstalled the flange to my judgement and matched its marks that I made with those of the differential. Is it a big deal the way how you install it? Or it only matters how driveshaft aligns to differential.
#13
While it might work, I would just leave the old grease alone. If you wanted grease that is definitely compatible, head to the VW or Audi dealer and pick up a tube.
#14
I wish I would seen this last night, but already have cleaned flange from grease last night to have reinstalled to differential and have it ready for today for new grease. I ran to autozone again today for more options
Both valvoline cans say they work in european cars and look like the valvoline synthetic durablend looks is the most suitable for this car. But I would go for the Mobil One synthetic, it was twice more expensive than other two which made me think its high quality grease, but it doesn't states it works in cv joints while the valvoline does and has more temperature range.
what I didn't cleaned is the driveshaft, it still has old grease, should I clean it too and replace it with this new grease or leave it like that?
#15
If its packed like this, and I also clean the old grease from driveshaft. will this be enough to lube the driveshaft when I reinstall it . Or its recommended to also have driveshaft greased at reinstallation?
#16
#17
I think youre right, I can't really decide what grease to use, should have waited before wiping and cleaning my flange from old grease, I think I might be heading to dealer and get the oem cv grease as you said. Never tought a grease decision debate would stop me from doing this project for a full day.
#18
can damage be caused by leaving driveshaft loose from carrier for a extended period of time for about 1 1/2 day, just like the second picure? Can it be supported from the middle with a aluminum wheel to keep it straight as possible so that it wont bend too much and damage the u-joint or the joint to rear differential.
#19
#20
Which is the right oem grease to use on driveshaft?
I went to an audi dealer and they got me a VW Grease for triple roller joint part # G-052-186-A3,
,but I was expecting I was going to get the the High Melting Point Grease for CV joints part # G-052-133-A3,
I believe I have to use the second one or do either one will work the same?
