Positions of Cylinders
Old 05-03-2009, 11:38 AM
New Member
JohnnySweet's Avatar
Default Positions of Cylinders
Hi guys,
a month ago the check engine light showed up, but the car war running just fine, so I thought there is no hurry.
A week ago the check engine light started to blink, the car lost power and the engine was running irregular. At this time I purchase a scan tool and got three codes.
P0300 random misfire
P0302 cylinder 2 misfire
P0306 cylinder 6 misfire
The mehanic wanted to charge me 600 $ to replace six spark plugs and six ignition coils.
I decided to do it by myself.
I bought 6 spark plugs and 2 ignition coils, beacause I just wanted to peplace ignition coil 2 and 6.
After changing the spark plugs there is no change.
Now I want to change the ignition coils on cylinder 2 and 6, but I realised that I do not know how the cylinders are positioned.
Can anyone help me out please?
Old 05-03-2009, 12:04 PM
AudiWorld Expert
Boston Driver's Avatar
I believe the cylinders start as #1 passenger side front, then working backwards to the firewall (back of engine compartment). The next row starts #4 (for V6, or #5 for V8).
So it would look like this looking down on the engine, with the front of the car below the diagrams:
V6:
3...6
2...5
1...4
V8:
4...8
3...7
2...6
1...5
Old 05-03-2009, 12:11 PM
New Member
You believe, or you know? ))
Okay, that's pretty good for now, I am going to try that.
I will let you know what happenen.
Old 05-03-2009, 12:34 PM
Tech Guru
4Driver4's Avatar
Very hard to help out without knowing the year and engine in your car. If it does not have individual coil packs, you are wasting money.
Old 05-04-2009, 07:04 PM
New Member
V6:
3...6
2...5
1...4
V8:
4...8
3...7
2...6
1...5
Sorry, I did not have any time to answer earlier, anyway you helped me a lot.
I changed the ignition coils and now it works perfect again.
Thank you very much!
Old 05-04-2009, 07:07 PM
New Member
Yeah, you are right, I should have mentioned that it is a 2003 V6 3.0, but the problem is solved by now.
Thank you anyway.
cedars30
2.0T FSI Discussion
03-29-2015 12:44 PM
$500
12-03-2006 03:57 PM
S4orceCT:( X Misfire
09-22-2006 07:06 AM
S4George
20
05-03-2006 10:56 AM
Quick Reply: Positions of Cylinders
