Pressure switch code problem 00819-30.00
I’m beating my head trying to figure this out . I replaced sensor with new from Audi,pump used, control head used (twice) checked signal wire back to head still same codes
does anyone know where the wiring is prone to fail or how to get the dash out of the way enough to inspect it?
When my 02 had this issue it was due to no refrigerant in the system. Bought it with a broken timing belt so I could not test A/C. Turns out there was a hole in the condenser. Maybe check that there is R134A in the system, needs a certain pressure before the compressor clutch will activate. Guessing ECON button is on the HVAC control unit?
OMP
07-12-2011 09:38 AM
cjloy
08-18-2008 12:32 PM
bodhi
04-04-2006 09:21 PM
