Puddle lights not working
They would probably both be on the same fuse. They pop off real easy you might want to take a look and see if the connection came loose or if you have a voltage tester see if it is getting juice or just a bad light. They are real easy to replace.
On side that doesn't work, when yo open the see if the interior lights come on and the door open indicator shows. If not the problem is door latch mechanism. If they work, it's the bulb.
Sylvestri (11-13-2023)
AlexA4B8Fan
A6 (C7 Platform) Discussion
10
03-05-2024 12:21 AM
