Secondary Air System P0491 & P0492
I bought a 2001 Audi A6 4.2 V8 this Saturday. 24-hours later, the check engine light came on! The codes are P0491 & P0492. Secondary Air System Fault. The car has 53,000 miles and is out of warranty.
Would anyone with a Factory/Bentley Service manual please help me diagnoze the solution?
Sincere thanks in advance.
Bobby.
bobbydash@comcast.net
Bobby.
My Bently says check fuses for air pump and check hoses
Here's a description (at URL below) of how to check the hoses, for some reason they shrink up.
You don't need to check the fuses, just hook up your vag-com and do an output test....it will whirl like crazy if it has power.
BTW, it's the same for the 40 valve A8 motor.<ul><li><a href="https://forums.audiworld.com/a8/msgs/19663.phtml">https://forums.audiworld.com/a8/msgs/19663.phtml</a</li></ul>
Re: where are you?? is it really cold where you're located?
No. I am in Chicago. The temperature yesterday and today were in the 70's.
What is the Emissions warranty on Audi's? Is it the same as bumper-to-bumper? 4years-50k miles?
Thx,
Thx,
Re: Secondary Air System P0491 & P0492
Incorrect flow bank 1 and bank 2? Remove the top engine cover and look at the vac line on the left side on the engine. It goes to a solenoid twords the rear. They will sometimes shrink and pull off. If that happened you just need to run a new length of hose. Good luck.
I could not even find the secondary air pump, nor the fuse nor the relay. I did find the vaccum lines and they seem just fine!
Please advise...
Bobby.
Please advise...
Bobby.
