So this morning my car told me i need service in 1200 miles, my car has
almost 83k and is a 01 2.7 tip. So whats this service suppose to intail. And how much is it going to cost me?
This
Engine Oil - Change the oil. · · · ·
Engine Oil Filter - Replace the oil filter. · · · · Engine - Check for leaks. · · · · Cooling System - Check the coolant level. Add coolant if necessary. · · · · Exhaust System - Check for damage and leaks. · · · · Engine, On-Board Diagnostic - Check Diagnostic Trouble Code Memory. Purge if necessary, where applicable. · · · · Doors - Lubricate door hinge mechanism. · · · · Battery - Check electrolyte level. Add if necessary · · · · Windshield Wiper and Washer - Check fluid level. Add fluid if necessary. · · · · Automatic Shift Lock (ASL) - Check operation, incl. park/neutral position switch, where applicable. · · · N/A Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation. · · N/A · Tires and Spare Wheel - Check for wear and damage. Check the pressure. · · · · Service Reminder Indicator Display - Reset the display. · · · · Brake system - Check for damage and leaks. Check thickness of pads and brake fluid level.* · · · · Drive Shafts - Check the boots. · · · · Road Test - Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning and power accessories. · · · · Lights - Check the lights. · · · · Front Axle - Check dust seals on ball joints and tie rod ends. Check tie rods. · · · · Haldex Clutch - Change oil and filter. N/A N/A N/A · Automatic Transmission - Check for leaks. · · · N/A Automatic Transmission Final Drive - Check oil level. Add if necessary. · · · N/A Manual Transmission - Check for leaks. · · N/A · Manual Transmission Final Drive - Check oil level. Add oil if necessary. · · N/A · Power Steering Fluid - Check fluid level. Add if necessary. · · · · Dust and Pollen Filter - Replace filter. · · · · Headlights - Inspect headlights. Adjust if necessary. · · · · Sliding Roof - Clean guide rails and lubricate with grease spray. · · · N/A Air Cleaner - Replace filter element. · · · · Spark Plugs - Replace the plugs. · · · · Ribbed Belt - Replace belt. · · · · V-Belt - Replace belt for 1.8L 5-Valve Turbo Engines ONLY · N/A N/A · |
Thanks, any idea what the average audi dealer charges for that
at least 500$ (my guesstimate) for 115/hr$ labor at dealership
This honestly can be done yourself for 100$
Filter + Oil Filter + Oil + Plugs Anyone else feel free to chime in a price guess but if you can't do that and you need the dealer to do it: <b>oily stuff</b> Engine Oil - Change the oil. · · · · Engine Oil Filter - Replace the oil filter. · · · (85-90$) <b>EZ stuff...</b> Engine - Check for leaks. · · · · Cooling System - Check the coolant level. Add coolant if necessary. · · · · Exhaust System - Check for damage and leaks. · · Engine, On-Board Diagnostic - Check Diagnostic Trouble Code Memory. Purge if necessary, where applicable. · · · · Doors - Lubricate door hinge mechanism. · · · · Battery - Check electrolyte level. Add if necessary · · · · Windshield Wiper and Washer - Check fluid level. Add fluid if necessary. · · · · Automatic Shift Lock (ASL) - Check operation, incl. park/neutral position switch, where applicable. · · · N/A Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation. · · N/A · Tires and Spare Wheel - Check for wear and damage. Check the pressure. · · · · Service Reminder Indicator Display - Reset the display. · · · · (probably 100$ to 150$) <b> fun stuff</b> Dust and Pollen Filter - Replace filter. · · · · (35$ - 50$ for filter + markup, installation 1 minute) <b> Not Fun stuff.</b> Spark Plugs - Replace the plugs. · · · · (....um 150$? @ 2.00$ a plug + swap out) Ribbed Belt - Replace belt. · · · · (not sure) |
^^^ oops look up ^^^
No need to go to a dealer...
I just did my 80K service myself
If everything is running fine and you have no problems or trouble codes and getting good gas mileage 22-25mpg Just do the following Air Cleaner - Replace filter element. · · · · Spark Plugs - Replace the plugs. · · · · Cabin Filter - Replace Fuel Filter - Replace Oil & Oil Filter change (Do it yourself or get it done) You can find instructions in the forums for all these. The ribbed belt can be replaced at 90K when you have to do the Timing belt replacement. The only addition things which I want Audi dealer to do and which are not included in the list are Brake fluid Flush Fuel Injection Cleaning Complete Vehicle inspection ($20.00) used a coupon and get it for Free they do all the above inspections as in the scheduled maintenance list.. Save yourself some money buy Genuine products from ECS Tuning you can get all the filters and spark plugs for about $150 and the toughest is the spark plugs change but it is well documented and it will take you about 2 hours, rest is very very easy. |
You havent told us your service history, if you dont know, have inspection done
at local indy shop. You'll save on labor prices, plus most of the indy techs have worked for AOA at some point.
With key off, push odometer knob, turn key on, kabamm 10,000 more miles to go!
Consults crystal ball.... $283.17
