Timing or Sensors?
Timing or Sensors?
So the other day I got done doing my Cam tensioner. I Put it back together enough to start it. I started first try and about 30 to 60 seconds in... it dies and wont start now after all this I get the vag and p3046 seems to be sticking around. I only worked on the driver side...That codes is for passenger right? and now it just spit firing.
Here's my-original post- How ****ed am i? DIY
P0346- Camshaft Postion sensor "A" Circuit Rang/Performance.
What bank is that? the battery is KO atm it needs a charge,to many dead starts. i scanned the car right before i gave up and the code is gone but battery to week atm. the car wants to turn over but wont it spit fires. the car started right up first time then died out about 20 seconds in. i got pics ill post asap.
Cam chain tension-er, went in to do cam seals cams came out. Driverside only.
Unless somebody tells me that this means the cams are out of line. Then this car is going to the ****ing junkyard in the next couple hours. But with that being said if it was misaligned why did it start up perfectly the first time? I only worked on the driver side which bank is that code for?
Jason @ Streetwerke
13
05-20-2012 04:24 AM
crew219
12
03-11-2006 06:08 PM
audiqv8
Audi 100 / A6 (C4 Platform)
12-07-2003 12:31 PM
mj42jackson
09-22-2003 01:30 PM
