Transmission rear too far to one side
#11
I used a laser beam to align the center bearing on my quattro when I had to replace the driveshaft. It has been vibration free since the install a couple of years ago.
#13
I was never going to buy a special tool for a one time use, so this worked out perfectly, with a tool that I already owned.
#16
Not much else to say, except that the laser lever throws out a straight laser line that can be lined up with the two CV joints. Then, when the center bearing carrier is also lined up (with the laser line in the center), the driveshaft is straight. That is the intent of the special tool that Audi charges way too much for, and is accomplished by other means. I was able to position the laser level on the ground, and cast the laser line up from below (I used jackstands in the process... I don't have a lift.)
#17
Sorry to bring this old thread back... but does the 3393 Front Subframe Alignment Tool actually work with an A6 C5? The links at ECS Tuning say it is not compatible. But here in this thread it appears you are successfully using the VAG tool 3393 with an A6 C5. True?
#18
VW Tool And Equipment
2801 80th Street
Kenosha, WI 53143
1-800-892-9650
Good luck!
#19
AudiWorld Citizen
I saw that tool, it has staggered sizes/shoulders, right? I checked my 2000 A6 C5 Quattro Tip when I did the D drum... the three stacked/alignment holes are all the same dia., I think. In any case, I decided not to buy that tool, and ended up using a deep socket, 20 mm dia, as I recall.
