Trying to fix an exterior door handle problem.
Only opens when fully extended. Took the door card off but I can't see the rod. I could feel the rod and the clip it was attached to. It was movable so I tried up and down and nothing changed. Is there a way to fix it by feel or do I need to remove another part?
You'll have to remove the door channel to access the inside of the exterior handle.
Once you remove the channel you'll be able to see whats going on. Jason |
Door channel being the window guide or the locking mechanism?
Door channel meaning the window guide.
Jason |
Originally Posted by Jason@ECSTuning
(Post 24179579)
Jason |
Originally Posted by Greyhound Guy
(Post 24181476)
I was afraid that's what you meant. I'm sure out's not a big deal though.
Good luck! Let me know if you have any questions. Jason |
It would also be useful to mark the exact positions of the screws with a permanent marker, since the whole door component carrier is adjusted to the body of the by these screws...
Thanks guys. Maybe this weekend.
