Very random 2.7t misfire
Car: 2000 A6 2.7t auto Quattro
Mileage: <180,000 So, I've been dealing with this misfire since purchasing the car in Sept. 2012. I purchased the car knowing it needed some work but it never misfired when on test drives. It started 2 days after purchasing and driving it home. The misfire comes and goes, usually after driving awhile(full warm up) and then sitting for about a half hour. The misfire is so bad the car shakes at idle, as if more then 1 cylinder is missing. I looked it up and google mentioned coil packs. I knew there was an oil leak and a coolant leak on the motor when I purchased the vehicle. Understanding most peoples lack of maintenance, I purchased a timing belt kit, spark plugs and coil packs, valve cover gasket kit, oil and air service kits. While replacing these items I also replaced the oil cooler coolant hose that had ruptured. All was good for a week or so, then came back the misfire. Now sometimes the missing begins at start up and goes away a few miles down the road or it starts up fine and then starts missing after driving most of the way. Understand this car only misfires 10-5% of the time. Most of the time it drives great. My daily drive requires lots of stop and go. When it's missing I can tell the catalytic converter (passenger side) is getting very hot. While missing and I give minimal throttle, it misses but chugs along, if I get on it, it stops misfiring in higher RPM's but then the CEL starts flashing, BAD, I know. This whole time I've been scanning the CEL's(see below) everything pointed to the EGT sensor on bank 1. So I finally replaced it! Now, not getting a CEL for the EGT but still getting the misfire. Still getting CEL's now different codes. This weekend I checked for vacuum leaks again, this time checked at the BOV's. The bank 1 is not holding vacuum. I still have a coolant leak at the aux H2O pump under the intake that needs to be sorted. When I replace that I will be using new intake gaskets, new injector o-rings, install the bank 2 EGT, all O2 sensors(only have done B1S1), the spider hoses(PCV) and BOV's(710N's)..Oh I've also replaced the fuel pressure regulator and the temp sender(old one black/new one green). After replacing the temp sensor I noticed the temp gauge didn't go to 12 o'clock anymore, now more between 11 and 12. All parts used are either Audi/VW, Bosch, Karlyn, NGK, MANN, gaskets and belt kit purchased from Bl*up*rts. Most parts are from Rock*uto, ECS, Bl*up*rts, or Adv*nced Autom*tion. Any help is super appreciated! CEL: 8/29/13 P1454 INTER P1131 INTER P0421 P1423 P1355 INTER P0300 P0301 P0303 INTER P1411 INTER P0306 INTER P1361 INTER P1624 INTER 8/29/13 cleared and reset P0300 P0301 P1355 P1131 INTER P0305 9/17/13 P1454 INTER P0300 INTER P0301 INTER P1355 INTER P0304 INTER P0303 INTER P1361 INTER P0305 INTER P0306 INTER P1423 INTER P1411 INTER P0421 9/17/13 cleared and reset P0421 P1131 INTER 1/26/14 P0421 P1361 INTER P0300 INTER P0301 INTER P1355 INTER P0303 INTER P0304 INTER P0130 INTER P0306 INTER P1131 INTER P1453 1/26/14 cleared and reset P1131 INTER P1361 INTER P0421 P1355 INTER 2/16/14 P0421 P1624 INTER P1361 INTER P1411 INTER P0300 P0303 P0306 P1355 P0301 P0304 INTER P0305 INTER P1131 INTER 2/21/14 P1364 INTER P0300 INTER P0304 INTER P1131 INTER P0421 P0303 INTER P1370 INTER P0306 INTER 2/21/14 cleared and reset P0300 P0306 P1370 |
Get yourself VCDS and a laptop. Clear all the codes and diagnose the misfire as soon as it occurs (even pull over to the side of the road if you have to.) At that point, only the most recent event will be the one you have logged. Fix that problem and move on to the next one. Do it often enough and you will eventually fix them all.
That said, here's what Ross Tech says about P1370: http://wiki.ross-tech.com/wiki/index...8/P1370/004976 |
Originally Posted by georgeb944
(Post 24542924)
When this misfire occurs:
Cold start(early morning): 5% Cold start(late afternoon): <20% Full tank fuel: 10% 1/4 tank: >50% Low ambient temp(winter): 20% high ambient temp(summer): 40% Warm start <30 min restart: 10% Warm start >30 min restart: >50% Starts fine then misfires while driving: 10% Starts misfiring then clears up: 25% Misfiring before refuel, then clears up after fill-up: 50% When I tell people my car is running like ****: doesn't misfire for a week When I tell people my car is running better: starts misfiring within 2 days After replacing a part or pair of parts: 2-5 days w/o misfire I've been wrenching on motors for 20+ years and have always done my own work. I've been a rental/heavy equip mechanic for 10 years. I am not a parts changer, I am a problem solver....Until this twin turbo, vacuum/ elect. sensor nightmare. This car has me and all the mechanics at my work stumped. Yes we work mostly on industrial diesels and large hydraulic systems but problems usually can be tracked down. |
Well, the ross tech wiki does mention the fuel pump relay. I would swap the #6 ignition coil with one of the others and see if the symptom changes. If the symptom doesn't change it might be the wiring or it might be the relay.
(I understand your frustration. I work on Porsche 944 turbos, and I used to think that they were complicated until I started to understand this 2.7t engine.) |
(Post 24542970)
(I understand your frustration. I work on Porsche 944 turbos, and I used to think that they were complicated until I started to understand this 2.7t engine.) Yesterday, after work, started fine, remembered needs water(leaky aux pump), open hood and here this high pitched noise from the back of bank2. Sounded a bit like an electric motor, spinning high RPM's that's fan blades were slightly touching / grinding on it's mount. That stopped within 30 seconds and the drive home fairly smooth, just approx 2 mins of misfiring during drive. I'm wondering secondary air injection pump? Also there is always a noise from under the passenger side, not vacuum leak more like high pressure thru a venturi. When doing the passenger side suspension, I see something has struck one of the fuel hard lines under the car. Right as they turn up at the inner fender well. I've also replaced the fuel cap and fuel filter. |
Originally Posted by CRSmith78
(Post 24542977)
Weird thing is most of my problems have always been at cyl 1 and gassy exhaust from bank1... Last weekend when doing some vacuum leak tests, I switched ICMs to see if the misfire moves. I noticed the thermal paste had hardened and they were not stuck to the sink any more.
Yesterday, after work, started fine, remembered needs water(leaky aux pump), open hood and here this high pitched noise from the back of bank2. Sounded a bit like an electric motor, spinning high RPM's that's fan blades were slightly touching / grinding on it's mount. That stopped within 30 seconds and the drive home fairly smooth, just approx 2 mins of misfiring during drive. I'm wondering secondary air injection pump? Also there is always a noise from under the passenger side, not vacuum leak more like high pressure thru a venturi. When doing the passenger side suspension, I see something has struck one of the fuel hard lines under the car. Right as they turn up at the inner fender well. I've also replaced the fuel cap and fuel filter. Two things, based on what you said, if you just tell everyone you know once a week that your car runs like crap, problem solved. Lol Sounds like you may have a boost leak which is bad news. You need to pull the spark plugs and read them. If you see a lean condition on 1 or more plug, (mixed with the airy sounds you hear) a boost leak is likely |
That high pitched dentist drill sound when you start the car cold is indeed the secondary air injection pump. Normal if it dies down after about 30 seconds. Not normal if it sets a CEL. VCDS has an output test for SAI that turns the pump on.
Update
This last weekend I spent it's entirety working on my 2000 A6 2.7t. These repairs were to hopefully find and fix the misfire culprit and also fix the coolant leak.
My replacement checklist: Aux. water pump w/ hoses PCV spider valve Bank 2 EGT Bank 2 sensor 1 O2 sensor During the tear down to get to the aux. water pump, I found one bad vacuum check valve and the lower line of the spider valve all but clogged up. There were a couple vacuum lines that were fairly spongy too. I also realized the coolant leak wasn't from the pump, but coming from the return heater hose connection. After checking the AWP it was not spinning like the new one, so in the new one went. Had to order the coolant hose and check valve so spent the rest of the weekend replacing vacuum lines and installing the B2S1 O2 sensor and B2 EGT. After replacing all found issues and reinstalling all parts in their perfectly routed spots. It started with no issues, idled very smooth and had power. I could now feel the turbos down in lower RPMs help the motor accelerate. I think to myself, it's fixed, finally! WRONG! After driving approx. 25 miles that evening, w/o issue, I take the car home. That morning I start up and drive the car to work(12 miles) w/o issue. After work, drive to Dr's appt(25+ miles) no issues, lots of power. After Dr's appt, restarts no issues, drive in stop and go for about 5 minutes...then it starts misfiring. Misfiring so bad the CEL starts flashing and at idle the motor drops to around 500rpm almost stalling. I get on the freeway, still misfiring, after a mile or so it stops, back to full power. Then exit freeway, misfires a bit, smooths out, then starts misfiring the rest of the way home. So the only items I haven't replaced are the downstream O2 sensors and the ICMs. I have switched the ICMs, so I will check the misfiring cylinders. I am at a loss, I can't replace every part on this motor, but I really can't give up on this car either. I've put to much into it. Does anyone know how to test the ICM's or ever have a misfire issue like this? |
To diagnose the ICMs, start carrying your laptop, software and cable with you. As soon as you experience a miss, pull over and pull the codes. Save them to the log, clear them, and continue to drive. If you still have a miss, pull the codes again, then swap the ICMs (the one closer to the firewall is for Bank 1) and see if the codes move with the ICM.
You will also need to carry a 7 mm socket to remove the ICMs from the intake. |
