08 A6 crank but won’t start
3.2 A6 cranks but won’t start, after letting car sit over night car will start and run for a couple minutes then stall out and won’t start back up again. Relays and fuses good, Replaced fuel filter, battery, plugs, coil packs, map sensor, cam sensors, engine timing solenoids, crank sensor, coolant sensor, high pressure fuel pump, cam follower, fuel rail pressure sensor, fuel injectors
Also, post a VCDS scan
Checked for any vacuum leaks only code getting is p0340 camshaft position sensors replaced them with new ones and still nothing. Tested wiring harness and it’s good I’ll check mass air flow sensor next
SparTTan
01-07-2008 11:05 AM
Audi Junkie
12v V6 Discussion
07-06-2006 03:07 PM
