2005 a6 3.2 heater core leak and replacement help
#11
ok guys the core is in and done. First off do not order a core from Rock Auto they have the core for up to 04, even though they list it as 05. I told them its wrong they dont really care. Second you DO NOT have to pull the dash.
I had an Audi tech from the dealer do the job for me at my shop, I didnt really get to take any pics, but I can tell you how he did it
-He removed the side of console both sides
-removed glovebox and cover under steering wheel.
-removed connections and coolant lines from engine compartment, and blew air down the lines to remove coolant from the core.
-threw a towel on each side of the floor removed the brackets along side the core, then removed the clips and clamps and the core slides right out
This obviously isnt a step by step, but it was very simple from what I saw, He had no hangups or issues and had the new core installed in less than an hr from the start. I ended up leaving, but he told me its a 2-3 hr job, and he has done over a dozen of them.
Hope this helps a little as I found zero information online about the replacement of the heater core for 2005+
#13
Thanks for the info. I just found this problem with my '13 S5, and I am hoping the B8.5 chassis is like your A6 and can be done without removing the dash.
jenkins214
07-17-2009 10:23 AM
computrtutr
04-01-2008 03:06 AM
Max_A6
07-14-2005 09:32 AM
