Go Back  AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C6 Platform) Discussion
Reload this Page >
2005 Audi A6 Upper Radiator Hose Replacement (Video)
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Old 10-16-2018, 09:51 AM
kelisko's Avatar
Default 2005 Audi A6 Upper Radiator Hose Replacement (Video)
My upper radiator hose nipple that returns coolant to the reservoir broke while cleaning my engine bay a while ago. This was probably weak for months or years and I never noticed. I barely touched that part and it exploded with coolant all over the place. If you believe your car is leaking coolant and you don't know where to start from, check that spot. I was able to fabricate a temporary nipple until the part I ordered gets delivered.
I also flushed the coolant and this video shows how to. It also shows how to remove the coolant reservoir and prepare a coolant mix. Enjoy!
kelisko is offline
Old 10-19-2018, 11:25 AM
LarryJa's Avatar
I had to change that same hose when the same nipple broke on me while doing my hpfp replacement. It is a weak point, over time.....
LarryJa is offline
Old 01-08-2019, 09:33 PM
broke mine off the same way, i just took the upper radiator hose off, ground the nipple flat and drilled the hole open to 1/8th npt. screwed a brass barbed nipple in using two part
epoxy on the threads, then a little bead of it around the bottom. 3000 mi so far and works fine. looks like it belongs there.
new to rings is offline
Old 01-08-2019, 09:35 PM
should have also mentioned that i tapped the hole after drilling it. the plastic is quite hard and holds threads
surprisingly well.
Old 02-11-2019, 02:35 PM
Default old hose wont come off
i saw you had the same problem that the old hose would not come off easily mine will not either i tried wd 40 but its not much help is there anything else you did to help loosen it ? thank you
954AudiA6 is offline
Old 02-11-2019, 10:35 PM
kelisko's Avatar
Did you pull the clips first?
No, I did not do anything else. I applied WD-40 lubricating oil at the base, let it penetrate for about 10 minutes then tried pulling again and I saw it move. So I wiggled it top to bottom, left to right until it came off. It will still be tight and you need to use force. Without the WD-40 it wouldn't budge at all.
kelisko is offline
qezel
01-28-2009 10:33 AM
raybog716
11
11-13-2008 05:18 PM
Dr.Duct_Mossburg
03-27-2008 08:04 AM
Ramoner
03-08-2006 03:39 AM
Sloooo4esT
Audi Original "S" Cars
11-23-2004 09:56 AM
Quick Reply: 2005 Audi A6 Upper Radiator Hose Replacement (Video)
