A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2006 A6 4.2 blue/white smoke from exhaust
Old 09-10-2016, 06:12 PM
audi5500's Avatar
Default 2006 A6 4.2 blue/white smoke from exhaust
I bought a 06 A6 back in march and i just notice that the car will throw out a white/blue smoke after i have to brake hard or after going down a steep grade hill for a mile or two than accelerating after i dont know why this is happening it doesnt smoke on cold start and it doesnt look like it does it under hard acceleration so im kinda lost. i did change the oil when i got it and am going to again in a few weeks. it does loose oil but i would imagine that most of it would be coming from the valve covers that are leaking. it has around 122,000 on the motor. Any ideas would be helpfull along with any insight.
Thanks
Old 09-11-2016, 07:16 AM
FL C6.5 Avant's Avatar
valve guides/stem seals?
jake brakin' (compression braking with closed throttle) sucks oil past the guides. open it up and all that oil now in the cylinders rapidly burns off.
Old 09-11-2016, 09:38 AM
LarryJa's Avatar
I'm with valve seals, as a syart
Old 09-11-2016, 10:16 AM
raj99's Avatar
Hi OP
As I said on the v8 forum, and like everyone else, get the valve covers done and then perform a dye test to determine where the leaks are originating from... You won't need to guess what to do next.
Old 09-11-2016, 01:39 PM
LarryJa's Avatar
I believe the OP is conveying that there is an exhaust smoke,, not an egine oil leak.
Old 09-11-2016, 01:51 PM
raj99's Avatar
Yes and that may be the case, however there is obviously some kind of leak occurring which is creating the exhaust smoke and a dye test may help determine that.
Old 09-14-2016, 05:37 PM
audi5500's Avatar
are you sure it couldnt be anything else??? what would suddenly cause those to go bad lack of maintenance from the previous owner?? i didnt get any service paperwork with it. could it be anything with the pcv system???
Old 09-16-2016, 03:52 AM
LarryJa's Avatar
Anything else will be much more expensive to rectify.
It's best to start by checking the most common & less expensive causes.
Old 09-16-2016, 09:10 AM
raj99's Avatar
Since you have no records and no idea on previous owner and how they abused the car... Yes it could be a number of other issues (ie head gasket), but start with what I suggested and go from there.
audi5500
4.2 V8 Discussion
09-10-2016 06:40 PM
BigMouse
Audi Original "S" Cars
05-06-2010 07:10 AM
joeq10
11
08-03-2007 06:08 AM
AlanBDahl
02-09-2004 05:36 PM
::zuprong::
Audi 100 / A6 (C4 Platform)
06-17-2002 07:20 AM
Quick Reply: 2006 A6 4.2 blue/white smoke from exhaust
