2006 A6 P2294 fault code and more
My A6 with 3.2 has the CEL and the "ESP off" indicator lights on. It is hard to start and runs a bit rough when cold. It smooths out somewhat when hot but is still not right. Fuel mileage has dropped from 22mpg to 19mpg. Car has 115,000 miles on it. Here are the fault codes and Freeze Frame. We can clear the codes but the P2294 comes back as soon as you start the engine and the other codes come back within a few minutes. The local shop is not sure if it's the High Pressure Pump/Regulator going bad or an electrical/wiring issue. He said there is power going to the regulator. This is not at a dealership. Thoughts??? Tests to try???
Friday,05,April,2013,12:04:03:44289
VCDS Version: Release 908.1
Address 01: Engine Labels: 06E-910-559-BKH.lbl
Control Module Part Number: 4F1 910 559 F HW: 4F1 907 559 A
Component and/or Version: 3.2l V6 FSI 0050
Software Coding: 01050106190F0120
Work Shop Code: WSC 02325 785 00200
4 Faults Found:
008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
P2294 - 009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 768 /min
Mass Air / Rev.: 103.6 mg/str
Temperature: 60.0°C
Pressure: 28.7 bar
Voltage: 12.14 V
Temperature: 39.0°C
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 448 /min
Mass Air / Rev.: 179.8 mg/str
Temperature: 60.0°C
Idle
Load: 35.3 %
Speed: 0.0 km/h
004440 - Manifold Pressure Sensor (G71): Implausible Signal
P1158 - 006 - Short to Plus
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Mass Air / Rev.: 87.2 mg/str
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Speed: 42.0 km/h
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 006 - Short to Plus
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Bin. Bits: 00000010
Readiness: 0000 0000
Friday,05,April,2013,12:05:41:44289
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Control Module Part Number: 4F0 910 517 L HW: 4F0 614 517 L
Component and/or Version: ESP 8.0 quattro H04 0090
Software Coding: 0020895
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 4
Reset counter: 81
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
Hex Value: 0x04C0
Hex Value: 0x4002
Hex Value: 0x0025
Hex Value: 0x01AD
Hex Value: 0x00FF
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 768 /min
Temperature: 60.0°C
Pressure: 28.7 bar
Voltage: 12.14 V
Temperature: 39.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 448 /min
Temperature: 60.0°C
Idle
Load: 35.3 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Speed: 42.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Bin. Bits: 00000010
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 81
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
Hex Value: 0x04C0
Hex Value: 0x4002
Hex Value: 0x0025
Hex Value: 0x01AD
Hex Value: 0x00FF
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 768 /min
Temperature: 60.0°C
Pressure: 28.7 bar
Voltage: 12.14 V
Temperature: 39.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 448 /min
Temperature: 60.0°C
Idle
Load: 35.3 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Speed: 42.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Bin. Bits: 00000010
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 81
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
Hex Value: 0x04C0
Hex Value: 0x4002
Hex Value: 0x0025
Hex Value: 0x01AD
Hex Value: 0x00FF
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 768 /min
Temperature: 60.0°C
Pressure: 28.7 bar
Voltage: 12.14 V
Temperature: 39.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
RPM: 448 /min
Temperature: 60.0°C
Idle
Load: 35.3 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Speed: 42.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 184247 km
Time Indication: 0
Date: 2013.04.04
Time: 17:48:14
Freeze Frame:
RPM: 1024 /min
Temperature: 90.0°C
Idle
Voltage: 13.87 V
Bin. Bits: 00000010
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 81
Mileage: 184244 km
Time Indication: 0
Date: 2013.04.04
Time: 17:44:03
Freeze Frame:
Hex Value: 0x04C0
Hex Value: 0x4002
Hex Value: 0x0025
Hex Value: 0x01AD
Hex Value: 0x00FF
Find your fault codes here - http://www.dtcdecode.com/P2433
<TABLE><TBODY><TR><TD class=tdTitle>Code:</TD><TD>P2433</TD></TR><TR><TD class=tdTitle>Category:</TD><TD>Powertrain</TD></TR><TR><TD class=tdTitle>Definition:</TD><TD>Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Bank 1
</TD></TR></TBODY></TABLE>
<TABLE><TBODY><TR><TD class=tdTitle>Make:</TD><TD>Audi</TD></TR><TR><TD class=tdTitle>Code:</TD><TD>P1158</TD></TR><TR><TD class=tdTitle>Definition:</TD><TD>Manifold Absolute Pressure Sensor Circuit Range/Performance</TD></TR></TBODY></TABLE>
<TABLE><TBODY><TR><TD class=tdTitle>Code:</TD><TD>P0068</TD></TR><TR><TD class=tdTitle>Category:</TD><TD>Powertrain</TD></TR><TR><TD class=tdTitle>Definition:</TD><TD>MAP/MAF - Throttle Position Correlation</TD></TR></TBODY></TABLE>
P2293 & P2294
Possible Causes:
Fuel Pressure too Low
Intake Camshaft Failure
Possible Solutions
Check Measuring Values for Fuel Pressure
Check for bent/squeezed Fuel Lines
Check Fuel Pressure System for Leaks
Check Fuel Filter & Filter in Fuel Pump
Check Fuel Quantity supplied by the Fuel Pump
Special Notes
Check Fuel Pressure
North American Region (NAR) check TSB 2015153 (01-09-03 > 15-10-01 > 15-10-02), the Intake Camshaft might have a worn out Fuel Pump Cam.
Check the Fuel Pressure first.
Special Functions
Checking Fuel Pressure
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
Coolant Temperature at least 80 °C
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Group 103
[Go!]
Field 1: Fuel Pressure (Low), Specification: 2800...7200 mbar
Field 2: Fuel Pump Adaptation, Specification: -1000...+1000 %
Group 140
[Go!]
Field 3: Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
Increase the Engine Speed while checking this value, the Pressure has to rise with the Engine Speed.
Group 230
[Go!]
Field 1: Specified Fuel Rail Pressure (High)
Field 2: Actual Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
Field 3: Deviation between specified and actual fuel pressure, Specification: max. 5.0 bar
[Done, Go Back]
[Close Controller, Go Back - 06]
North American Region (NAR) check TSB 2018183 (20-08-01) and verify the High Fuel Pressure Sensor (G247) Part Number
Possible Causes:
Possible Solutions
Special Notes
Check Fuel Pressure
Special Functions
Prerequisites:
Ignition ON
Engine ON (Idle)
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Group 103
[Go!]
Group 140
[Go!]
Group 230
[Go!]
[Done, Go Back]
hans_7828
11-29-2017 04:41 AM
SchwarzS6
VAG-COM Discussion
02-10-2011 10:54 AM
