2006 A6 Quattro 3.2L Won't Start
First, I'd like to thank everyone involved with this forum. I have been using it to answer questions for a long time, even though I haven't been a member of the forum until today.
Car Info before Accident: 3.2L with 60,000 that had just started leaking oil from Valve Covers, Timing Chain Covers, and 2 cam sensors (Exhaust cam),according to the local Audi dealer. Price to fix $11000-$15000.
So, I was involved in a fender bender. I was hit in the rear end, not very hard, but once it came back from the body shop is when all of this started. But in all honesty, I'm thinking it's just coincidence. Only the rear bumper cover was involved. When I picked the car up the check engine light was on. Until that day it had never come on. The mechanics at the body shop said it was the Crank Positioning Sensor. So I leave the body shop and head to the self serve car wash. I figured regardless of who was putting it in, I should get the engine nice and clean. As I left the car wash, within 1 mile the car died. Being an oldish man I chalked it up to washing under the hood. After 2 series of cranks the car started up and didn't think about it again.
Fast Forward 1 month. I'm on the Expressway and I get on it to pass someone. As soon as the RPMs broke 6000 the ECS light came on and a message that said "ESP Fault Please See Your Owners Manual". The car went into a high idle low power mode. The car was still capable of driving fast but the RPMs were much higher than normal. I got off the expressway and when I came to a stop the car was running poorly, like a big cam lope, almost stalling. I turned it off and restarted it, it ran fine. It did it to me one more time in the next day or 2. I order the Crank Positioning Sensor and managed to change it even with popeye forearms. The check engine light went off, life is good.
The next day the car did the same thing as what had happened on the expressway but this time I was doing 30 mph and maybe 2000 rpm or less. I pulled over to the side of the road but this time it stalled. That was the last time it was capable of being driven. Currently, I can start the car and it runs for 3-4 seconds. Smooth the first second or 2 but then sputtering to a stop. After that is only cranks. Give it some alone time (a few hours) and it will do the same except for ever run smooth. It will only run smooth the first start of the day. Now to me, that sounds like the High Pressure Fuel Pump but I'm not sure.
Now, I've read this answers on this site long enough to know "You need a Genuine Ross-Tech Dongle and their software to check the codes". So, I did get that ordered today. I did have a friend stop by this morning on his way to work, as a mechanic, and he ran what he could with the standard OBD II scanner and this is what he got: (My Biggest worry is the timing advanced to 13.5 degrees, but I'm not sure if these values are from when it died or from the last 4 second start?)
Vehicle VIN: WAUDH74F06N125137
Vehicle Manufacturer: Audi
Vehicle Calibration ID: 4F1910559E
0060
Current Fault Log
P0341: Camshaft Position Sensor "A" Circuit Range/Performance (Bank 1 or Single Sensor)
P0366: Camshaft Position Sensor "B" Circuit Range/Performance (Bank 1)
P0136: O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0301: Cylinder 1 Misfire Detected
P0302: Cylinder 2 Misfire Detected
P0303: Cylinder 3 Misfire Detected
P0340: Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
U3FFF: Unknown code - More information may be available on the web
Pending Fault Log
P2127: Throttle/Pedal Position Sensor/Switch E Circuit Low Input
P0068: Unknown code - More information may be available on the web
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Fuel Status = 0 byte
Engine Load = 95.294 %
Engine Coolant Temperature = 219.2 °F
Fuel Trim Bank 1 Short Term = -30.469 %
Fuel Trim Bank 1 Long Term = 0.781 %
Fuel Trim Bank 2 Short Term = 0.781 %
Fuel Trim Bank 2 Long Term = -8.594 %
Intake Manifold Pressure = 13.924 psi
Engine RPM = 6,324 rpm
Speed (OBD) = 87.613 mph
Timing Advance = 11.5 °
Intake Air Temperature = 102.2 °F
Throttle Position(Manifold) = 87.843 %
Run time since engine start = 2,312 s
Fuel Rail Pressure = 1,434.423 psi
Barometric pressure (from vehicle) = 14.359 psi
Voltage (Control Module) = 13.152 V
Engine Load(Absolute) = 96.078 %
Commanded Equivalence Ratio(lambda) = 0.866
Relative Throttle Position = 90.196 %
Ambient air temp = 91.4 °F
Absolute Throttle Position B = 87.059 %
Accelerator PedalPosition D = 81.569 %
Accelerator PedalPosition E = 81.176 %
End of report.
0060
Test report:
MID:$01 TID:$79
- O2 Bank 1 Sensor 1
Max: -2.99827V Min: 3.25398V
Test result value: 0V
FAIL
MID:$01 TID:$81
Max: 4.99712V Min: 1.25514V
FAIL
MID:$01 TID:$83
Max: 0.819 Min: 0
Test result value: 0.074
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Test incomplete or dependant test failed
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 4.99224V Min: 0.01952V
Test result value: 0.0732V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.20048V Min: 0V
Test result value: 1.11752V
PASS
MID:$02 TID:$81
Max: 0.72712V Min: 0V
Test result value: 0.66856V
PASS
MID:$02 TID:$82
Max: 4.99712V Min: 0.75152V
Test result value: 0.77104V
PASS
MID:$02 TID:$83
Max: 0.20008V Min: 0V
PASS
MID:$05 TID:$83
- O2 Bank 2 Sensor 1
Max: 0.819 Min: 0
Test result value: 0.093
PASS
MID:$06 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
Max: 0.7076V Min: 0.7076V
Test result value: 0.7076V
PASS
MID:$06 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 0.01952V
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 1.02968V
PASS
MID:$06 TID:$81
Max: 0.71248V Min: 0V
Test result value: 0.69784V
PASS
MID:$06 TID:$82
Max: 4.99712V Min: 0.73688V
Test result value: 0.8296V
PASS
MID:$06 TID:$83
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
MID:$22 TID:$84
- Catalyst Monitor Bank 2
MID:$3b TID:$81
- EVAP Monitor (0.090")
Max: 65,535ms Min: 1,230ms
Test result value: 15,000ms
PASS
MID:$3b TID:$82
Max: 1,010ms Min: 0ms
Test result value: 0ms
PASS
MID:$3b TID:$83
Max: 25Count Min: 0Count
Test result value: 0Count
PASS
MID:$3b TID:$84
Max: 23.7 Min: 0
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
Max: 65,535ms Min: 4,370ms
PASS
MID:$3d TID:$81
- EVAP Monitor (0.020")
Max: 2.96044% Min: 0%
Test result value: 1.47717%
PASS
MID:$3d TID:$82
Max: 15.25695% Min: 2.1364%
Test result value: 6.55875%
PASS
MID:$3d TID:$83
Max: 1.99882 Min: 0.03999
Test result value: 0.17876
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 900°C Min: 720°C
Test result value: 818.60004°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 43,320Ohm Min: 0Ohm
Test result value: 802Ohm
PASS
MID:$45 TID:$85
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 815.70001°C
PASS
MID:$46 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 2
Test result value: 786Ohm
PASS
MID:$50 TID:$2b
- O2 Heater Monitor Bank 4 - Sensor 4
Max: 20,846 Min: 55,344
Test result value: 14,451
FAIL
MID:$50 TID:$51
Max: 65,535 Min: 65,535
Test result value: 65,535
PASS
MID:$81 TID:$6a
- Fuel System Monitor Bank 1
Max: -24,566 Min: 24,688
Test result value: 27,264
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 48Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 38Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 54Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 1,235Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 67Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
Thanking you in advance for any input you may have. Just a quick FYI, I have searched the forum for this answer but I can't seem to find anyone with a vehicle with my codes that isn't running. Everything I've found with those fault codes, the vehicle is still running. If I have screwed up anywhere, as far as my thread placement or lack of information, please only jump down my throat with 1 foot. Lol.
0060
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
End of report.
0060
Test report:
MID:$01 TID:$79
FAIL
MID:$01 TID:$81
FAIL
MID:$01 TID:$83
Max: 0.819 Min: 0
PASS
MID:$02 TID:$01
MID:$02 TID:$02
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
PASS
MID:$02 TID:$83
PASS
MID:$05 TID:$83
Max: 0.819 Min: 0
PASS
MID:$06 TID:$01
PASS
MID:$06 TID:$02
PASS
MID:$06 TID:$07
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$21 TID:$84
MID:$22 TID:$84
MID:$3b TID:$81
PASS
MID:$3b TID:$82
PASS
MID:$3b TID:$83
PASS
MID:$3b TID:$84
Max: 23.7 Min: 0
PASS
MID:$3c TID:$81
PASS
MID:$3d TID:$81
PASS
MID:$3d TID:$82
PASS
MID:$3d TID:$83
PASS
MID:$41 TID:$85
PASS
MID:$42 TID:$81
PASS
MID:$45 TID:$85
PASS
MID:$46 TID:$81
PASS
MID:$50 TID:$2b
FAIL
MID:$50 TID:$51
PASS
MID:$81 TID:$6a
FAIL
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
OK, I got my new Ross Tech cable in today. I went from not having enough information to being dumbfounded by the VDCS program. I monkeyed around and figured out how to run some tests, as well as getting some fault logs. The first one had a lot of low power faults because the battery had gotten low. I reset them and ran another auto-scan. Here is what I got. I'm starting to think that maybe me car jumped time?
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 E HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0060
Revision: --H15--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 02325 785 00200
VCID: 2D04011D011EB9DFC0C-8078
3 Faults Found:
000832 - Camshaft Position Sensor (G40)
P0340 - 006 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 10:23:35
Freeze Frame:
RPM: 224 /min
Mass Air / Rev.: 528.6 mg/str
Temperature: 28.5°C
Start
Bin. Bits: 00000100
Speed: 0.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 13:33:31
Freeze Frame:
RPM: 576 /min
Mass Air / Rev.: 425.1 mg/str
Temperature: 28.5°C
Idle
Load: 85.5 %
Speed: 0.0 km/h
000769 - Cylinder 1
P0301 - 006 - Misfire Detected
Freeze Frame:
Fault Status: 00010001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.09
Time: 11:29:56
Freeze Frame:
RPM: 1248 /min
Mass Air / Rev.: 452.4 mg/str
Temperature: 27.0°C
Idle
Time: 0.0 s
Speed: 0.0 km/h
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4121693
Coding: 0000002
VCID: 2616FE3124E88A87016-8072
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
4 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 14
Reset counter: 240
Mileage: 170903 km
Time Indication: 0
Date: 2017.07.21
Time: 17:02:43
Freeze Frame:
Hex Value: 0x8C00
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A6
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 60
Reset counter: 200
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.08
Time: 22:00:37
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x5282
Hex Value: 0x0024
Hex Value: 0x0176
Hex Value: 0x00FF
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 240
Mileage: 172936 km
Time Indication: 0
Date: 2017.08.20
Time: 12:57:02
Freeze Frame:
Hex Value: 0x5800
Hex Value: 0x5302
Hex Value: 0x0003
Hex Value: 0x1667
Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 240
Mileage: 172962 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:23
Freeze Frame:
Hex Value: 0x4E00
Hex Value: 0x5302
Hex Value: 0x001B
Hex Value: 0x1066
Hex Value: 0x06FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10604000309670
Coding: 0000011
Shop #: WSC 02323 785 00200
VCID: 6390A725175A3FAF268-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H39 0040
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 240
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:49
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.06
Time: 11:08:06
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303LQ057513573
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 313C1D6D1D26DD3FE44-8064
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H09 0060
Subsystem 2 - Serial number: 00000002106585
Subsystem 3 - Serial number: 0111.04.130000000100010031ÿ
Subsystem 4 - Serial number: 010031ÿ
5 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 193
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:02:08
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 9
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.08
Time: 22:00:09
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 240
Mileage: 172251 km
Time Indication: 0
Date: 2017.08.08
Time: 22:57:06
Freeze Frame:
Bin. Bits: 01
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 235
Mileage: 172251 km
Time Indication: 0
Date: 2017.08.08
Time: 22:57:39
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 240
Mileage: 172938 km
Time Indication: 0
Date: 2017.08.20
Time: 12:58:28
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030080202
Coding: 0524326
VCID: 5BE09FC52F2A076F6E8-800E
2 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 10
Reset counter: 240
Mileage: 170378 km
Time Indication: 0
Date: 2017.07.05
Time: 08:29:55
Freeze Frame:
Temperature: 25.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:55:50
Freeze Frame:
Voltage: 8.10 V
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0014123
VCID: 2A0E0A0130F0AEE725E-807E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7263077
Shop #: WSC 00000 000 00000
VCID: 1C62DCD96AA44057A72-8048
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 240
Mileage: 172980 km
Time Indication: 0
Date: 2017.08.20
Time: 13:34:41
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 2
Reset counter: 232
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 17:56:42
Freeze Frame:
Text: 00000000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 172980 km
Time Indication: 0
Date: 2017.08.22
Time: 12:44:51
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Mileage: 170432 km
Time Indication: 0
Date: 2017.07.07
Time: 13:17:04
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0B0VZL
Coding: 0013878
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0D713D345
Subsystem 3 - Serial number: 6342CSME0D71643FB
Subsystem 4 - Serial number: 6352QSME071237074
Subsystem 5 - Serial number: 6362QSME07542F77P
Subsystem 6 - Serial number: 63734SME07572C797
Subsystem 7 - Serial number: 63834SME07264F272
1 Fault Found:
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90055053310063
Coding: 0002021
VCID: 6696BE31E4684A87C16-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 28
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2017.08.18
Time: 18:42:27
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H11 0630
Revision: 00100000 Serial number: 4R8159RC5
Coding: 0083263
Shop #: WSC 26761 001 1048576
VCID: 1E66D6D17CB85247496-804A
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.08
Time: 21:57:24
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805C0603D9
Coding: 6CFE73CD1B1104
Shop #: WSC 02334 785 00200
VCID: 2708F33523E2938F3A0-8072
4 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 19:56:55
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:04:39
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:07:03
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 200
Mileage: 172962 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:26
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 619CAD2D0D462DBF344-8034
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 240
Mileage: 172884 km
Time Indication: 0
Date: 2017.08.18
Time: 16:47:18
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00000000 Serial number: ry
Coding: 0035563
Shop #: WSC 02327 785 00200
VCID: 2C020C193A04B0D7D72-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.02
Time: 20:12:28
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01008898410000
Coding: 4618301
VCID: 2E0606110C18C2C7F96-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 240
Mileage: 172980 km
Time Indication: 0
Date: 2017.08.20
Time: 13:36:58
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 229
Mileage: 170111 km
Time Indication: 0
Date: 2017.06.16
Time: 15:12:42
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 229
Mileage: 170111 km
Time Indication: 0
Date: 2017.06.16
Time: 15:12:45
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000200833
Coding: 0000016
VCID: 2514F93D59EE819F08C-8070
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 12:52:15
Freeze Frame:
Voltage: 8.30 V
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 158
Reset counter: 240
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:20:00
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000012939
Coding: 0002114
VCID: 5EE696D13C381247096-800A
2 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172960 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:00
Freeze Frame:
Voltage: 8.400 V
Temperature: 30.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 240
Mileage: 172884 km
Time Indication: 0
Date: 2017.08.18
Time: 16:54:00
Freeze Frame:
Voltage: 8.400 V
Temperature: 23.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00000000 Serial number: 6
Coding: 0035563
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 240
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:51
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
VCID: 5DE491DD313E095F10C-8008
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 172960 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:59
Freeze Frame:
Voltage: 7.45 V
Count: 200
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 280AF0092EFC9CF733A-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
4 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 172888 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:55
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 172888 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 172888 km
Time Indication: 0
Date: 2017.08.18
Time: 16:53:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 172936 km
Time Indication: 0
Date: 2017.08.18
Time: 18:55:21
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394LU057633105
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 240
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:57:57
Freeze Frame:
Fault Priority: 7
Fault Frequency: 200
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.06
Time: 11:08:13
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000173367
Shop #: WSC 08213 444 58529
VCID: 2310E72557DA7FAF668-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2511211478
Coding: 344630393135313035432056413032353131323131343738
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 34
Reset counter: 255
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 19:20:01
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 22
Reset counter: 255
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 19:26:28
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 6
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 19:14:12
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 12:58:32
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 240
Mileage: 172951 km
Time Indication: 0
Date: 2017.08.20
Time: 13:07:37
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0035370
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 11:57:30
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700015344
Coding: 0062221
VCID: 221EE22148C076A76DE-8076
1 Fault Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172963 km
Time Indication: 0
Date: 2017.08.20
Time: 13:17:25
Freeze Frame:
(no units): 79.0
Voltage: 8.30 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0035370
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:46, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
Gateway Installation List: 4F0 910 468 A
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 10:23:35
Freeze Frame:
RPM: 224 /min
Temperature: 28.5°C
Start
Bin. Bits: 00000100
Speed: 0.0 km/h
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 13:33:31
Freeze Frame:
RPM: 576 /min
Temperature: 28.5°C
Idle
Load: 85.5 %
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.09
Time: 11:29:56
Freeze Frame:
RPM: 1248 /min
Temperature: 27.0°C
Idle
Time: 0.0 s
Speed: 0.0 km/h
Coding: 0000002
Coding: 0020895
Coding: 0000011
Cannot be reached
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:18:17
Freeze Frame:
Temperature: 29.0°C
Coding: 0014123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Cannot be reached
Coding: 0013878
Coding: 0002021
Coding: 0083263
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 200
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:19:12
Coding: 0082946
Coding: 0035563
Coding: 4618301
Cannot be reached
Coding: 0002114
Coding: 0035563
Revision: C63C0030
Coding: 0005022
Coding: 0000016
Address 56: Radio
Cannot be reached
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:19:33
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:19:43
Coding: 0035370
Coding: 0062221
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172963 km
Time Indication: 0
Date: 2017.08.20
Time: 13:17:25
Freeze Frame:
(no units): 79.0
Voltage: 8.30 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0035370
Cannot be reached
End----------(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.3V)-----------
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 10:23:35
Freeze Frame:
RPM: 224 /min
Temperature: 28.5°C
Start
Bin. Bits: 00000100
Speed: 0.0 km/h
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 13:33:31
Freeze Frame:
RPM: 576 /min
Temperature: 28.5°C
Idle
Load: 85.5 %
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.09
Time: 11:29:56
Freeze Frame:
RPM: 1248 /min
Temperature: 27.0°C
Idle
Time: 0.0 s
Speed: 0.0 km/h
Coding: 0000002
Coding: 0020895
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 240
Mileage: 170903 km
Time Indication: 0
Date: 2017.07.21
Time: 17:02:43
Freeze Frame:
Hex Value: 0x8C00
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A6
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 60
Reset counter: 200
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.08
Time: 22:00:37
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x5282
Hex Value: 0x0024
Hex Value: 0x0176
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 240
Mileage: 172936 km
Time Indication: 0
Date: 2017.08.20
Time: 12:57:02
Freeze Frame:
Hex Value: 0x5800
Hex Value: 0x5302
Hex Value: 0x0003
Hex Value: 0x1667
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 240
Mileage: 172962 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:23
Freeze Frame:
Hex Value: 0x4E00
Hex Value: 0x5302
Hex Value: 0x001B
Hex Value: 0x1066
Hex Value: 0x06FF
Coding: 0000011
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 240
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.06
Time: 11:08:06
Coding: 0000003
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 193
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:02:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.08
Time: 22:00:09
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 240
Mileage: 172251 km
Time Indication: 0
Date: 2017.08.08
Time: 22:57:06
Freeze Frame:
Bin. Bits: 01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 235
Mileage: 172251 km
Time Indication: 0
Date: 2017.08.08
Time: 22:57:39
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 240
Mileage: 172938 km
Time Indication: 0
Date: 2017.08.20
Time: 12:58:28
Coding: 0524326
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 240
Mileage: 170378 km
Time Indication: 0
Date: 2017.07.05
Time: 08:29:55
Freeze Frame:
Temperature: 25.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:55:50
Freeze Frame:
Voltage: 8.10 V
Coding: 0014123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 240
Mileage: 172980 km
Time Indication: 0
Date: 2017.08.20
Time: 13:34:41
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 232
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 17:56:42
Freeze Frame:
Text: 00000000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 172980 km
Time Indication: 0
Date: 2017.08.22
Time: 12:44:51
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Mileage: 170432 km
Time Indication: 0
Date: 2017.07.07
Time: 13:17:04
Coding: 0013878
1 Fault Found:
Coding: 0002021
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 28
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2017.08.18
Time: 18:42:27
Coding: 0083263
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.08
Time: 21:57:24
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 19:56:55
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:04:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:07:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 200
Mileage: 172962 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:26
Coding: 0082946
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 240
Mileage: 172884 km
Time Indication: 0
Date: 2017.08.18
Time: 16:47:18
Coding: 0035563
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.02
Time: 20:12:28
Coding: 4618301
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 240
Mileage: 172980 km
Time Indication: 0
Date: 2017.08.20
Time: 13:36:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 229
Mileage: 170111 km
Time Indication: 0
Date: 2017.06.16
Time: 15:12:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 229
Mileage: 170111 km
Time Indication: 0
Date: 2017.06.16
Time: 15:12:45
Coding: 0000016
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 12:52:15
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 5
Reset counter: 240
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 20:20:00
Coding: 0002114
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172960 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:00
Freeze Frame:
Voltage: 8.400 V
Temperature: 30.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 240
Mileage: 172884 km
Time Indication: 0
Date: 2017.08.18
Time: 16:54:00
Freeze Frame:
Voltage: 8.400 V
Temperature: 23.0°C
Coding: 0035563
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 240
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:51
Revision: C63C0030
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 172960 km
Time Indication: 0
Date: 2017.08.20
Time: 13:16:59
Freeze Frame:
Voltage: 7.45 V
Count: 200
Coding: 0000016
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 172888 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 172888 km
Time Indication: 0
Date: 2017.08.18
Time: 16:52:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 172888 km
Time Indication: 0
Date: 2017.08.18
Time: 16:53:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 172936 km
Time Indication: 0
Date: 2017.08.18
Time: 18:55:21
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 240
Mileage: 172886 km
Time Indication: 0
Date: 2017.08.18
Time: 16:57:57
Freeze Frame:
Fault Priority: 7
Reset counter: 240
Mileage: 172234 km
Time Indication: 0
Date: 2017.08.06
Time: 11:08:13
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 34
Reset counter: 255
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 19:20:01
Freeze Frame:
Fault Priority: 7
Fault Frequency: 22
Reset counter: 255
Mileage: 172198 km
Time Indication: 0
Date: 2017.07.30
Time: 19:26:28
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 19:14:12
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 12:58:32
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 240
Mileage: 172951 km
Time Indication: 0
Date: 2017.08.20
Time: 13:07:37
Coding: 0035370
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.07
Time: 11:57:30
Coding: 0062221
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172963 km
Time Indication: 0
Date: 2017.08.20
Time: 13:17:25
Freeze Frame:
(no units): 79.0
Voltage: 8.30 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0035370
Cannot be reached
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 10:23:35
Freeze Frame:
RPM: 224 /min
Temperature: 28.5°C
Start
Bin. Bits: 00000100
Speed: 0.0 km/h
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.08
Time: 13:33:31
Freeze Frame:
RPM: 576 /min
Temperature: 28.5°C
Idle
Load: 85.5 %
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.09
Time: 11:29:56
Freeze Frame:
RPM: 1248 /min
Temperature: 27.0°C
Idle
Time: 0.0 s
Speed: 0.0 km/h
Coding: 0000002
Coding: 0020895
Coding: 0000011
Cannot be reached
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:18:17
Freeze Frame:
Temperature: 29.0°C
Coding: 0014123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Cannot be reached
Coding: 0013878
Coding: 0002021
Coding: 0083263
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 200
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:19:12
Coding: 0082946
Coding: 0035563
Coding: 4618301
Cannot be reached
Coding: 0002114
Coding: 0035563
Revision: C63C0030
Coding: 0005022
Coding: 0000016
Address 56: Radio
Cannot be reached
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:19:33
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 172933 km
Time Indication: 0
Date: 2005.02.11
Time: 09:19:43
Coding: 0035370
Coding: 0062221
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 172963 km
Time Indication: 0
Date: 2017.08.20
Time: 13:17:25
Freeze Frame:
(no units): 79.0
Voltage: 8.30 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0035370
Cannot be reached
A4_Jax
12
07-26-2006 03:48 AM
pdxaudi3.2
Pacific Northwest Discussion
13
07-13-2006 08:30 PM
banal
Mid Atlantic Discussion
10-07-2005 12:38 PM
