2006 Audi 3.2 liter camshaft Adjuster
Hi,
Does anyone know how you would diagnose a bad camshaft adjuster? On you tube there is a video for the 4.2 8 cylinder engine which shows internal damage and recommends replacement when doing the timing chains and tensioners.
Since I did the L/R tensioners, I can't get the car to run well enough to even hold an idle. A scan keeps showing the P0346 implausible signal at G163, bank 2 intake cam position sensor. When I check time, I am able to lock the cams and pin the crank.
How would I know if I have a bad intake camshaft adjuster?
Anyone been down this path?
Thanks in advance for any info provided.
Check your cam to cam chains under the valve covers. Failed adjusters can go metal to metal and start the shaving. If it has... id go aftermarket adjusters and chains, change the oil and filter twice to pick up all the parts. And use a flush on first draining. Also put on new cover gaskets while its apart.
There are also vacuum driven intake plane adjusters that can break off, fall into intake, and rattle above the valves. There is a thread about someone having this issue.
Hi,
After that, I'd be suspicious of the cam position sensor. I think typical diagnosis of that is by swapping the sensor around & seeing if the reading moves or remains.
While I've never had your problem, those are recurring issues that have shown up in valve tensioner threads/posts.
Note: I'm monitoring my start up noisy tensioner to change it myself as it worsens.
Are you certain that you've gotten the cam adjusters properly installed pretensioned & torqued?
xspiritdannyx
12
02-03-2016 07:52 AM
Small Town Terrorist
Audi allroad
16
12-31-2008 09:15 AM
OneGuyInCA
11
02-16-2008 09:14 PM
Rolf
04-17-2007 09:51 AM
OldManTan
04-01-2007 03:14 PM
