2007 S6 driver door latch failing
So I’ve replaced my drivers door latch twice now and it needs to be replaced again all within the past 9 months. First time it wouldn’t lock and I had to use the key to lock it. Second time it thought the door was always open and now it won’t unlock unles it’s done manually.
I noticed when I replaced it last time that the latch assembly was wet. That got me thinking it’s probably supposed to be dry in there and that’s what’s causing the failure. Is there supposed to be a weather shield in the door that keeps the latch dry? Or is the window supposed to seal tightly at the bottom preventing water from getting in there?
Any other thoughts on this? Am I missing something obvious?
saifxnyc
10
09-25-2019 11:15 AM
geordie
12-30-2006 10:07 AM
door won't close; latch is broke. where to get a new latch from? part that holds door shut to pillar
b5t
04-06-2005 10:09 PM
Creaking in rt door latch-sounds like the body tweaking and causing that noise in the latch? anyone?
TittieTwister
09-10-2003 07:36 AM
