A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2008 Audi A6 Oil overfill
Old 08-18-2018, 12:01 PM
Mel Latal's Avatar
Default 2008 Audi A6 Oil overfill
2008 Audi A6 quattro. I accidentally overfilled the oil and the car does not shift. I placed the car on ramps, drained the oil and filled it with 6.9 quarts as recommended by the user manual. I started the car and checked the dipstick and it was over the max level. I drained half of the oil out, started the car and the car does not shift. I ran VCDS and I am getting engine fault 005668 MIL Request Signal Active (check TCM for errors too) and Transmission error 009984 Transmission Friction Element / Clutch A. Any ideas what to do? Thanks.
Old 08-19-2018, 03:06 AM
Tech Guru
4Driver4's Avatar
Troll?
It’s been years since I’ve seen one of those “I tried to change the engine oil but accidentally drained the ATF instead” posts.
Old 08-19-2018, 03:29 AM
Mel Latal's Avatar
Default Not drained ATF
Originally Posted by 4Driver4
Troll?
I am a fairly new to Audi's. I've owned one and regularly changed the oil for last three years, so I am pretty sure I did not drain ATF fluids instead of an engine oil. Thanks for for your reply. Not helpful though.
Old 08-19-2018, 09:47 AM
raj99's Avatar
You over filing your oil has nothing to do with your transmission error codes - unless you really did accidentally drain that instead
I'd recommend checking your transmission fluid and since you've just likely never changed that or the filter ... It's probably well past due.
mmedic
A6 (C7 Platform) Discussion
10-16-2018 04:00 PM
first.octopus
06-16-2015 08:41 AM
mojohio
Q7 MK 1 Discussion
9
11-08-2007 12:22 AM
rmazook
Audi 100 / A6 (C4 Platform)
01-15-2006 02:52 PM
Max_A6
02-28-2005 04:54 AM
Quick Reply: 2008 Audi A6 Oil overfill
