2009 lane change assist Control Module 2
Audiworld Senior Member
Anyone know where this module is located? Got a failure the last two days and VCDS tells me the module is defective. Anyone know where it is located?
TIA
AJG
TIA
AJG
Did you ever figure this out?
I have the same year A6 as yours. The DTC is a result of a failed side assist module located in the rear bumper(there are two of them in total). I know one of them is bad, but don't know the way to narrow it down. If I pull the driver side(slave), I still get the code. If I pull the passenger side(master), I can't reach the modules. If I swap them to opposite sides, same thing, no reach.
My best guess right now is that it's the master module. However, is the code a result of the module being reached but then a detection of an electrical fault? Or is the code more generic in that whether it's defective or just not there, the same code will result? Also, from what I could gather, CPU 2 could either mean master or slave?
16365 - Control Module - Electrical Error; CPU 2
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
014 - Defective
Freeze Frame:
Fault Priority: 3
It's either the wiring or the slave module behind the driver side rear bumper cover in my case - best bet is the module. Module itself is the most expensive (there's a surprise) - the slave being more expensive then the master (different part numbers also) and this version the most expensive of all from what I can tell. Audi wanted $1500+ to repair which involves taking off the bumper, replacing the module, and re-calibrating with a mirror setup. I was told the module has to have a specific SW rev. Car has never been hit in rear so I'm guessing mine is a module failure.
https://www.audiworld.com/forums/q7-.../#post25358957
I'm going to reach out to @dukesean and see if he knows more on this.
I read on this page that as long part number and software number match, no calibration is necessary. But my money is somewhat on that the part number itself doesn't matter so much as software number.
You all get it figured out? My Lane change assistance control module 2 has failed on my Q5 TDI and I prefer not spending thousands of dollars to get lights to show on mirrors.
Thanks
Thom
Thanks
Thom
Yes. Purchased a used slave module on ebay for $100 with the right PN and Software code. Easy install and system works like a charm. I did not take it to Audi to have it "aligned" and it seems to pick up vehicles just fine. Installed it in my A6 but I think the part was out of a Q5 so there is some commonality. Did not have to remove entire bumper cover on the A6, just the one side and bolts on the other. Then was able to swing out the bumper cover enough to easily change the slave module. Only problem I had was putting it back together with the mud flap screws being so rusted.
mine is module 2 per my VCDS. So that is passenger side?
Thanks
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 D HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0010
Revision: 00H01000 Serial number: 6PZ 009 014-15
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2F6DE3E4BE6521370E-807A
Subsystem 1 - Part No: 4L0 910 568 D
Component: J0770_SWA_Slave_H01 0010
Subsystem 2 - Serial number: 6PZ 009 014-35
Subsystem 3 - Serial number: 5F03.02.0900H010003CN10368ÿ
Subsystem 4 - Serial number: N10368ÿ
1 Fault Found:
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 232248 km
Time Indication: 0
Date: 2019.12.28
Time: 13:34:15
I am torn on which one is giving me fits since drivers side is 8T0 907 566 B and passenger side is 8T0 907 568 B (when I climb under the car)
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0335713137
Coding: 010211
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU21.rod
VCID: 3FDB424B27F35E03B69-806B
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0335135384
Coding: 010211
1 Fault Found:
730117 - Control Module 2 for Lane-Change Assist
C1115 F0 [009] - Automatic Calibration Not Possible
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 158046 km
Date: 2021.06.30
Time: 11:32:48
Coding: 010211
Coding: 010211
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 158046 km
Date: 2021.06.30
Time: 11:32:48
