3.0 A6(S/C) throwing p0492 p0491
So, as the title mentioned I'm having some trouble with my a6 throwing these 2 codes on a cold start, I cleared my codes after I had noticed I had a misfire and replaced my coil packs and plugs. Seemed to eliminate the issue for a couple days. It returned today, same two codes, seems to idle a little wonky until it's in operating range.
it has a weird clatter sort of sound when it first starts from like deadline cold (wasn't ran for at least 12 hours)
https://www.autocodes.com/p0492_audi.html
Could be an air leak issue.
Hey man, thanks for the tip, I'll try listening around a bit under there see if I can catch a leak with some soapy water. Shes '10 so shes still relatively newish. Most of my hoses lool rather fresh. I'll see about getting a vcds scan.
I wouldn't use soapy water, especially if it's a vacuum leak...you know where that water will go, it's not the same as a leak in your tire which will bubble up. Smoke test would be the best, but you really need to get a better scan to even really begin problem solving.
schaeffer
02-03-2022 10:33 AM
JeterLeto
02-09-2015 05:09 PM
