Key Stuck in Ignition
The last few times that I have driven my '07 A6, the key has gotten stuck in the ignition. It usually takes several minutes of messing around with the steering wheel and putting it in park and drive, etc. before the key will release in park. Has this happened to anyone else. Is there an easy solution that I don't know about?
Hey man i have a 05 a6 and when I tell you i had the EXACT same problem I did....I had to replace the key and the ignition switch ,only reason why I had to get a new key is because when I brought the car only one key came with it. However if I am not mistaken the dealership charged $300 for the new ignition switch but that is what you will have to do to solve your problem...As for me with the new key and ignition switch I have not had any problems so far (knock on wood) I hope everything works out for you too
I had the same problem. The Tiptronic shifting assembly is out of alignment and the ignition interlock is not releasing when put in Park. Simple mechanical adjustment is needed.
If you have some mechanical skills you can do it yourself. To get to the assy you need to take off the center console.
