Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
- Audi A6 C6 3.2L V6: How to Inspect and Clean Intake Valve Carbon Deposits
Step by step instructions for do-it-yourself repairs
3.2L FSI, How to inspect carbon deposit on intake valves and clean it
#14
Part question?
I am going to clean carbon deposit from my valves. The question i have is do i need to get two of each gaskets or this part number is for set? Thank You.
Gasket set - upper intake 06E-129-717-B (two or one?)
Gasket set - lower intake manifold 06E-198-717-A (one or two?)
#15
Good luck on your carbon cleaning.
Please report back on your progress and finding.
#17
C.R. Brown,
I am not a superman. One hour is for Part A Inspection only. Whole job will take all Saturday plus night for a shade tree mechanic.
gk1 and mystrodo,
Thanks for complements.
I used Seafoam and have a write up ready to post but can not post a new thread anymore. I got this message "Post rejected because of a score of: 43 Rejection set to: 30." I e-mailed webmaster and pierreb yesterday for fix.
The blasting material you mentioned is walnut shell. I did some research about it. There is cheap machine that needs an air compressor.
My Audi had 58K miles and the real issue I had was check engine light because of a faulty high pressure fuel pump. Before that I noticed slight rough idle at first startup when cold from the time I bought it as used car at 46K. I actually took it to dealer for that and got typical "no problem found" response.
gk1 and mystrodo,
#18
#20
Cleaning those valves takes about 15 to 20 minutes per cylinder if you would like to make them nice and shiney! About an hour of R&R time, and I always run a BG fuel injection cleaner thru the FSI injectors.
Then they run nice and smooth!
