4.2 V8 (MPI) with 190A Alternator
My 2004 A6 (C6) has the 4.2lt V8 40v (MPI) with engine code: BAT
I had the specs pulled via the VIN and this lists PR Code 8GH - Alternator 190 A
So far I've not removed the under engine cover to actually look but from what I've discovered online it would seem this car might have a water cooled alternator?
Since I got the vehicle in November last year I've noted my rear demister isn't functioning, when pressed the led lights up momentarily on the console then switches off by itself, Searching here has pointed me towards the voltage regulator as a possible cause.
I ran a diagnostics a couple of nights back and had this come up
Does anyone know if the voltage regulator can be replaced without having to remove the alternator from the vehicle?
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000044075
Shop #: WSC 63830 981 12485
VCID: 234FF155E2CED91
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2703070891
Coding: 344630393135313035442056413032373033303730383931
Shop #: WSC 63830 741 68830
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Mileage: 1048575 km
Time Indication: 0
Date: 2019.06.03
Time: 16:30:46
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 215
Mileage: 106743 km
Time Indication: 0
Date: 2019.06.03
Time: 23:37:14
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 106753 km
Time Indication: 0
Date: 2019.06.05
Time: 06:00:32
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 106753 km
Time Indication: 0
Date: 2019.06.05
Time: 06:00:42
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 106753 km
Time Indication: 0
Date: 2019.06.05
Time: 06:00:52
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 1048575 km
Time Indication: 0
Date: 2019.06.03
Time: 16:30:46
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 215
Mileage: 106743 km
Time Indication: 0
Date: 2019.06.03
Time: 23:37:14
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 106753 km
Time Indication: 0
Date: 2019.06.05
Time: 06:00:32
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 106753 km
Time Indication: 0
Date: 2019.06.05
Time: 06:00:42
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 106753 km
Time Indication: 0
Date: 2019.06.05
Time: 06:00:52
To answer one of your questions, yes the alternator in your vehicle is water cooled. As for replacing the voltage regulator without removing the alternator...if by voltage regulator you are referring to the battery regulator, well that's in your trunk. I would also strongly recommend you check that your battery is good since the Quiescent errors are typically related to a low battery.
And I did mean Voltage Regulator, that goes in the back of the alternator. as opposed to the Battery Regulator located in the trunk. I've found the replacement part online but unsure if it can be fitted without fully removing the alternator from the vehicle first.
Cheers.
I would second what Raj said. Give the battery an overnight trickle charge, clear the stored error codes and scan again. You may even fix the demister suddenly works again with a fully charged battery, since the energy management system disables non-essential systems when battery power is low.
I appreciate your responses and I'll take your suggestions under advisement, however nobody has answered my actual question of whether or not the voltage regulator can be swapped out without having to fully remove the alternator.
MT-tec
02-24-2003 04:00 AM
SiV6Qcoupe
9
11-26-2001 05:21 AM
