A6 2005 C6 3.2FSI
A6 2005 C6 3.2FSI
Hello, 3.2FSI engine cylinder 5 misfire showing on UBD check, engine running rough. Replaced coil and spark plug, car was running fine and after a week same thing happened with cylinder 5. Replaced all coils and spark plugs, the car was running perfect for 3000km and after 2months again cylinder 5 misfire. Replaced the coil and spark pug, done vacuum sea foam engine treatment. And after a week the same thing happens again. Can someone help!
Hello thanks for reply, car has only 75000 km, full service was done by Audi dealership 4 months ago. What is involved in replacing vacuum and what it is? Paid over $2k for the last service and I know they will take me for a ride if I drop the car to them. It could be something minor like electrical connection because when I tapped the top of coil a few times with small hammer the car started idling way better with CEL light off and the light came back on after a few minutes idle .
I don't think it is injector because when I change coil the car runs fine for a day or so. Might have to a leak down test can that be done easily or by dealership only?
Are the vacuum lines separate for each cylinder? How do you check them? I am in Australia, warm climate and dealer told me the cars do not have carbon build up problems here. Car has a low milleage.
michael4702
04-28-2014 02:47 AM
markcincinnati
A4 (B8 Platform) Discussion
31
02-25-2009 10:01 AM
