A6 Gateway Module Install? Programming? Help please!
My MMI failed for the second time in 2 years. The MMI board itself is actually fine, it's the module behind the glove box that's actually failed. I've copied a pic for reference (it's part #1). The install process of the unit looks fairly easy, but my shop was wondering if there was any coding beyond the install? They inquired about a Workshop Code - what is that exactly? I'm simply in need of details of what needs to be done with VAGCom to complete the entire install process?
Part # is: 4F0910732QX
scope of work
" PERFORM RING BREAK AND TECH DIAG. TRACED SOURCE OF MALFUNCTION TO 07 MODULE.
REMOVE GLOVE BOX, REPLACE UNIT, CODE, ADAPT, UNLOCK. CHECK OPERATION , OK"
if you dont mind me asking, what was the price for it??
thank, and good luck.
That's insane for labor. From what I know, it's a 1 hour install job - you just drop the glove box (there are 4 bolts that hold it) and everything is accessible to you immediately. Remove the old module, and install the new one.
The coding doesn't take longer than 30 minutes, as far as I know.
i hope they spend it, just the way they earn it.
Arnold K.
VAG-COM Discussion
01-11-2013 03:34 AM
YumyJager
10
06-05-2003 07:49 PM
