2004 A6 quattro p0455
2004 a6 4.2 Quattro
p0455 evap leak, replaced fuel cap
smoke test, leak above fuel tank
not familiar with audi evap
anyone do this repair or drop tank, heads up on possibilities before I drop it. I appreciate any info or direction I can get.
thank you
Justin
thank you
Justin
Your vehicle is a C5, so post the question on the c5 subforum.
You can call the dealership to see if that car was done, outside of this I really can't say much more but you can search the forum about this recall.
BTW here is the bulletin link https://www-odi.nhtsa.dot.gov/recall...intVersion=YES
Note: Your car might not fall into this but you should still check with the dealership.
I've always had this evap code and not sure if this was done on mine but, replacing the N80 valve (when it stops working) and the fuel cap (I've replaced the O-ring) some times does this and other times MIL goes away. If the cap seats properly, it works I guess. Need to buy another cap.
Interested in the exact location where you patched with epoxy..
Contact the nearest dealer and have them check the VIN # to see if the recall was done. I bought my 2004 A6 in late 2014. Took it in for service in early 2015. The dealer said it needed the recall and it was done at no cost. Worth checking in to. If you're near Tucson, Chapman is the dealership. They will most likely provide a loaner while your vehicle is being worked on to do the recall. Only takes a few hours but recommend you schedule an early time for your appointment. Not a big fan of dealers but in this case, yeah.
I know, but the thought of taking my car to the dealer(or other auto repair places) scares the daylights out of me!
I'll call them and give the VIN to see if it is done without giving my car. Also, I'll see what's the actual repair involved with bulletin.
Your reply inspired me to start a new thread (check it out : Tales from the autoCrypts)
host23age
07-02-2011 07:54 PM
