AC Problems
AC Problems
2011 A6 3.0
4 days ago AC worked fine - almost too cold as usual.
Yesterday - warm/hot air only.
I hooked up just the valve/gauge part of an AC recharge unit and the pressure sits at 100% continuously - I know that usually if it is undercharged when the compressor kicks on it will usually drop down.
Any thoughts - I have not looked at the compressor yet to see if it's actually turning on or not. I hope I can see that semi-easily.
I am going to check fuses tonight.
2011 A6 3.0
Ok, I can't say for sure that's the problem, but for sure I've seen many threads talking about warm air from the vents with the cause being cited as the G395. There's a service bulletin from Audi about it too.
I bought my replacement on eBay for around 25 British pounds (worth approximately diddly squat since Brexit!) so it doesn't have to be an expensive job to fix. I'd have swapped mine already if it wasn't Provo g to be tricky to get the front bumper off.
Next the bumper can come forwards further (I left the other side 10mm nut in place) and the bracket directly above the G395 gets unscrewed and removed then the shroud covering the electrical connector can be released with a small torx screw (hard to see).
Unbolting the G395 and re-fixing the new one takes just minutes and there is no need to de-gas the system. I re-used the same O ring which was already on there as it seemed fine.
Looks complicated when you write it out, but a pretty easy job.
Awesome, I am going to do it this weekend. I found this entry on an A5 forum (with the 3.0) engine and it looks to be the exact same.
Air con pressure sensor G395 replacement - Audi A5 Forum & Audi S5 Forum
I did order the 24mm crowfoot spanner to help with removal so I do not have to remove the bumper.
Thanks again!
Thanks again!
Ok. Sadly not exactly like that on the A6. Not unless your A6 is very different to mine, and I assume they're all made the same in Germany. You will find once you've removed the top cover panel you can only just see the G395, which is fitted with a horizontal orientation, not vertical as it appears to be in that pic of an A5. There is a supporting bracket for the front bumper which needs to be taken out before you can get to it, plus the shroud I mentioned before.
As I say, at least one fella claims he did it without taking the bumper off and with that crowfoot spanner you will stand a chance, but it's going to be awfully tight.
Good luck though, you might be much more of a mechanic than me (wouldn't be hard!)
