Audi a6 2008 tail lights - AudiWorld Forums
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Old 01-13-2018, 07:49 AM
Default Audi a6 2008 tail lights
hi
I have a 2008 A6. There is a warning sign that appeared mentionning that my rear back light, rear fog light and rear brake light (all 3) need to be changed about 1 month ago. The warning appears about 1 minute after the car is started. I finally decided today to change all the bulbs. Same warning appears with the new bulbs! I left my tail light dissasebled to further determine the problem. I start the car, all the tail light bulbs light up. No warning message. After about 30 seconds, the tail lights all close and the warning appears immediately. Thus, obviously not the bulbs the problem. Is there a fuse for the rear right tail lights?
thanks!!
John1972 is offline
Old 01-13-2018, 05:58 PM
mikerouze's Avatar
I had a similar issue a while ago, it ended up being corrosion on the ground pin in the tail light connector. I feel like it would be worth a shot to take a look. It's not too difficult to get the tail lights out of the car.
mikerouze is offline
Old 01-13-2018, 06:10 PM
Default Audi a6
Hi,That is exactly what I did after a bit of ressearch. I disconected the connector, used sandpaper to sand the aluminium pin of the brown connector, reconnected everything and.... it work!!!Thanks
John1972 is offline
Old 01-20-2018, 03:32 PM
Worked perfectly for..... a week! Warning back on today. Any other suggestions?
Thanks
John1972 is offline
Old 01-20-2018, 03:52 PM
raj99's Avatar
Thanks
Hi John
There's a few threads on this issue and the only real fix is to get new rear light assembly.
raj99 is online now
Old 01-20-2018, 04:03 PM
Thanks for the info. I found someone who said that he twisted the ground pin by 10 degrees which solved the problem.
Thanks once more
John1972 is offline
Old 01-20-2018, 04:49 PM
KevinGary's Avatar
Originally Posted by raj99 View Post
Hi John
Listen to Raj. He is right.
KevinGary is offline
Old 01-28-2018, 06:16 AM
I had the same issue...and went with the fix that works, a new light assembly.
psychogecko is offline
Old 01-28-2018, 06:53 AM
Default Tail lights
Since I twisted the ground aluminium male portion of the plug by 10 degrees and put small paper staples lateral the the female pins to make the connection tighter, the warning signal has not recurred ( repair done 8 days ago. Hope it stays like that...)
John1972 is offline
Old 02-17-2018, 06:10 AM
Warning lights still not back!! Think that is the solution to the problem...
John1972 is offline
Quick Reply: Audi a6 2008 tail lights
