Vendor for ABS Module rebuild
I had a local guy do a VagCom scan on my 2005 A6's (3.2) ABS/ESB error indicating a parking brake malfunction.
Here's what came back:
From this, I'm finding that I'm most likely needing an ABS module rebuild. I've seen mention on here Module Masters and Cheap-ABS. My A6 seems to have the Bosch 8.0 module, which both places can repair.
MM wants $350.00 for it.
Cheap-ABS wants $239.00 for it.
My questions to you folks out there that have used either service are:
Which one did you use and why?
Are you happy with the results?
How long ago did you do the work and how is it holding up?
How did you go about removing the module? Link to how you removed would be great as I do NOT want to screw that up!
Thanks for any information you guys may have. I TRULY appreciate it!
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Control Module Part Number: 4F0 910 517 L HW: 4F0 614 517 L
Component and/or Version: ESP 8.0 quattro H03 0090
Software Coding: 0020895
Work Shop Code: WSC 02335 785 00200
VCID: 2D5A1A5FB4ABE976001-8078
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 13
Mileage: 182108 km
Time Indication: 0
Date: 2014.03.17
Time: 18:01:41
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x001C
Hex Value: 0xB197
Hex Value: 0x00FF
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 13
Mileage: 182108 km
Time Indication: 0
Date: 2014.03.17
Time: 18:01:41
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x001C
Hex Value: 0xB197
Hex Value: 0x00FF
Have you read through this: https://www.audiworld.com/forums/sho...ht=ABS+rebuild
As for removal, it's pretty straightforward, in fact module masters (I believe) gives a walk through on how to remove it. In my previous Audi MM did the job and it lasted over 4 years, I sold the car...so no idea after the 4.
Had not seen that, but thanks for that pointer. Looks like another common problem with these.
But I'm encouraged that your experience with MM was good. Thanks for that feedback. I'll look at that BBA site mentioned in that thread.
